Maclocks Surface Pro 3 Space Enclosure Swing Arm Wall Mount - Black
Quicklinx: B8DQWS00 Mfr#: 827B530GEB
The Surface Tablet Space Enclosure Swing secure mount is the ideal Surface Tablet security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Space Enclosure for Surface Tablet Kiosk has open corners for proper ventilation and access to the audio and charging ports for continuous charging. These features allow for a fully functional device even when locked in the Surface Tablet Enclosure. The keyed lock makes it easy to access when tablet maintenance is required.
The Surface Tablet Space Enclosure Swing mount is the perfect solution for corners, bar table tops, under cabinets, or simply where some extra versatility or space is needed. The tension screws allow for precise fluid or locked movement and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation modes.
Compulocks Surface Secure Space Enclosure with Swing Arm Kiosk Black enclosure - for tablet - black
Enclosure - wall-mountable, desktop, under-the-cabinet
Recommended Use
Tablet
Recommended Display Size
12"
Material
Aluminium
Microsoft Surface Pro 3
Material
Aluminium
AV Furniture
Enclosure
Recommended Use
Tablet
Placing / Mounting
Wall-mountable, desktop, under-the-cabinet
Cable Management
Integrated cable management
12"
Adjustable depth, portrait to landscape movement, lockable, swivel adjustment, cable lock, ventilation system, padded
Dimensions & Weight Details
Dimensions
Enclosure - width: 30 cm, depth: 2 cm, height: 23 cm
