Maclocks Surface Pro 3 Space Enclosure Swan Mount Kiosk - Black
Quicklinx: B8DSWS00 Mfr#: 179B530GEB
The Swan Surface Tablet Kiosk is the newest release from Compulocks. Elegantly designed with a white "swan-neck" sloping stand your Surface Tablet Kiosk bring a level of class to any setting.
The surface tablet stand is angled at 60 degrees for optimal viewing and sits 14 inches (35 cm) high and at the base is 7 inches (18 cm) wide. The enclosure rotates 90 degrees for smooth transition between landscape and portrait mode.
The wiring will come out the rear of the stand for a clean look and the base can be bolted to a counter top for security. It has a keyed lock for easy access to the your Surface Tablet when you need to take it with you or maintenance is required.
Compulocks Surface Secure Space Enclosure with Swan Stand Kiosk Black enclosure - for tablet - black
Enclosure - desktop
Recommended Use
Tablet
Recommended Display Size
12"
Material
Aluminium
Image Colour Disclaimer
The displayed product image may be a different colour
Microsoft Surface Pro 3
Material
Aluminium
AV Furniture
Enclosure
Recommended Use
Tablet
Placing / Mounting
Desktop
Cable Management
Integrated cable management
12"
Portrait to landscape movement, lockable
Dimensions & Weight Details
Dimensions
Enclosure - width: 30 cm, depth: 2 cm, height: 23 cm
