Maclocks Orientation Swivel VESA Plate Portrait-Landscape Views Black
Quicklinx: B8B3WS00 Mfr#: VRP-B
£22.54 ex VAT
£27.04 inc VAT
Maclocks VESA Swivel Plate counter top or wall mounting base adds another level of functionality to the enclosures.
Compulocks Vesa Rotating Plate mounting component - black
Mounting component - wall-mountable, counter
Mounting Components
Swivel plate
Adjustments
Rotation
VESA Mounting Interface
Material
Steel
Compulocks Adjustable Height VESA Mount Security Lock Floor Stand For Tablets, Adjustable VESA Floor Stand Silver, BrandMe VESA Brandable Floor Stand For Tablets, iPad 10, Rise Space Kiosk, Space Rise, Space Swing, Space Swing Arm iPad 10; Space Rise iPad Enclosure Kiosk XLow-Rise
Material
Steel
AV Furniture
Mounting component
Mounting Components
Swivel plate
Placing / Mounting
Wall-mountable, counter
Adjustments
Rotation
Horizontal or vertical screen orientation
Compulocks Adjustable Height VESA Mount Security Lock Floor Stand For Tablets, Adjustable VESA Floor Stand Silver, BrandMe VESA Brandable Floor Stand For Tablets, iPad 10.2" Space Enclosure Swing Wall Mount, Rise Space Kiosk, Space Adjustable iPad Enclosure Floor Stand, Space Rise, Space Swing, Space Swing Arm iPad 10.2-inch Enclosure , Compulocks Space Rise iPad Enclosure Kiosk XLow-Rise , Maclocks Rokku
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: B8B3 046566
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £3.15
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Maclocks
Stock Status: Used Stock
