Maclocks Mac Mini Lock
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: B84ZWS00 Mfr#: MMEN76
15 In Stock
£34.96 ex VAT
£41.95 inc VAT
Well it doesn't get much easier, you can mount the Mac mini using a security bracket to any surface utilizing the standard set of 75 or 100 VESA mount holes. This Mac mini mount is made from 100% solid high grade aluminum construction and makes for a great security solution. You slide the Mac mini into the Mac mini mount and security bracket, secure the lock in place and you are good to go - all in seconds. The loop-ended security cable is galvanized steel and the cable can be looped around a stationary object.
  • Versatile placement
    Designed for flexibility, this Mac Mini Security Mount can be easily mounted under desks or on walls, providing a secure and out-of-the-way solution for your Mac Mini
  • Durable construction
    Crafted from high-quality aluminum, the Mac Mini Security Mount ensures a sturdy and reliable hold, protecting your device from theft or tampering
  • Enhanced compatibility
    With VESA interface support along with rear and top mounting options, this system security kit offers a seamless fit for your Mac, enhancing its usability and security without compromising on design
Compulocks Mac Mini Security Mount - system security kit
System security kit
Placing / Mounting
Wall mountable, under-desk mountable
Package Content
Lock
Product Material
Aluminium
Top mountable, rear mountable, VESA interface support
Apple Mac mini (Early 2020, Early 2023, Late 2012, Late 2014, Late 2018, Late 2020, Mid 2020)
System security kit
Placing / Mounting
Product Material
Aluminium
Package Content
Lock
B84Z Maclocks Universal Laptop Cable Lock In Stock £17.47
Brand: Maclocks
