Maclocks iPad  360 Kiosk -  Black
Quicklinx: B859WS00 Mfr#: AIO-B
Stock Status: In Stock, Used Stock
22 in stock
£105.25 ex VAT
£126.30 inc VAT
Maclocks iPad All in one combines all the advantages of the new iPad Enclosure, with an all-in-one counter-top bracket, making it a perfect all-inclusive iPad security kiosk, iPad Kiosk for education, health-care, corporate, retail and point of sale environments.
Compulocks Executive 360 iPad 9.7" Counter Top POS Kiosk Tablet Stand - stand
Stand
30 cm x 2 cm x 20 cm
2.72 kg
Recommended Use
Tablet
Material
Aluminium
Apple 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad (3rd generation); iPad 2; iPad Air; iPad Air 2; iPad with Retina display (4th generation)
30 cm
2 cm
20 cm
2.72 kg
Material
Aluminium
AV Furniture
Stand
Recommended Use
Tablet
Rotating, lockable, swivel adjustment, cable lock, tamper-resistant
Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad (3rd generation) , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad with Retina display (4th generation)
Maclocks iPad  360 Kiosk -  Black Bundle deal on Maclocks iPad 360 Kiosk - Black
£204.42
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: B859 038864
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £16.87
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Maclocks
Stock Status: Used Stock
Price Range Ex VAT: 100 - 150
