The Galaxy Tab 3 Enclosure secure Kiosk is the ideal Galaxy security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The 360 All In One Kiosk has a full tilt for an easy was to reverse the screen for ideal viewing and safe interaction. A wiring pass-through cutout keeps the look clean and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation needs.
The Galaxy Tab 3 360 All In One Enclosure Kiosk is closed on all sides to provide a tamper-proof security solution but has a cutout inset for access to all the buttons on the front bezel. The charging cable is secured within the enclosure with an opening for the wire to allow for mounted charging. The Kiosk can be fastened to a table top or flat service through the holes in the base of the stand.
The Galaxy Tab 3 Enclosure Kiosk has a stable, all steel base to prevent tip-overs at any screen angle.
- Compulocks Full Jacket 360 Galaxy Tab 3 10.1" Counter Top Kiosk Black stand - Tilt & Swivel - for tablet - black
- Product Type
- Stand (Tilt & Swivel) - desktop
- 30 cm x 2 cm x 20 cm
- Pan
- 360°
- Adjustments
- Tilt
- 544 g
- Recommended Use
- Tablet
- Material
- Aluminium, steel
- Black
- Designed For
- Samsung Galaxy Tab 3 (10.1 in)
- 30 cm
- 2 cm
- 20 cm
- 544 g
- Material
- Aluminium, steel
- Black
AV Furniture
- Stand
- Design
- Tilt & Swivel
- Recommended Use
- Tablet
- Placing / Mounting
- Desktop
- Pan
- 360°
- Adjustments
- Tilt
- Portrait to landscape movement, lockable, swivel adjustment, tamper-resistant
Dimensions & Weight Details
- Dimensions
- Base - width: 13.8 cm, depth: 12 cm, height: 18 cm
- Designed For
