The Galaxy Tab 1/2 and Galaxy Note 10.1 Enclosure 360 All In One Kiosk is the ideal Galaxy security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The 360 All In One Kiosk has a full tilt for an easy was to reverse the screen for ideal viewing and safe interaction. A wiring pass-through cutout keeps the look clean and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation needs.
The Galaxy Tab 1/2 and Galaxy Note 10.1 Enclosure 360 Kiosk is closed on all sides to provide a tamper-proof security solution. The charging cable is secured within the enclosure with an opening for the wire to allow for mounted charging. The Kiosk can be fastened to a table top or flat service through the holes in the base of the stand.
The Galaxy Tab 1/2 and Galaxy Note 10.1 Enclosure 360 All In One Kiosk has a stable, all steel base to prevent tip-overs at any screen angle.
- Compulocks Galaxy Secure Metal Jacket Enclosure with Rotating 360° Kiosk Black stand - Tilt & Swivel - for tablet - black
- Product Type
- Stand (Tilt & Swivel) - desktop
- 30 cm x 2 cm x 20 cm
- Pan
- 360°
- Adjustments
- Tilt
- Recommended Use
- Tablet
- Material
- Aluminium, steel
- Black
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Designed For
- Samsung Galaxy Note 10.1, Note 10.1 LTE, Note 10.1 WiFi, Tab 10.1, Tab 10.1 WiFi, Tab 2 (10.1), Tab 2 (10.1) WiFi
- 30 cm
- 2 cm
- 20 cm
- Material
- Aluminium, steel
- Black
AV Furniture
- Stand
- Design
- Tilt & Swivel
- Recommended Use
- Tablet
- Placing / Mounting
- Desktop
- Pan
- 360°
- Adjustments
- Tilt
- Portrait to landscape movement, lockable, swivel adjustment, tamper-resistant
Dimensions & Weight Details
- Dimensions
- Base - width: 13.8 cm, depth: 12 cm, height: 18 cm
- Designed For
