Product
Maclocks Compulocks Universal Secure Enclosure "Rokku" (Premium Line)
Quicklinx: CSCGWS00 Mfr#: 140B260ROKB
Stock Status: Clearance, Used Stock
Sorry but this product has been discontinued.
View used stock
The Rokku design includes a recessed frame for a full tamper proof enclosure. Access to the on/off and volume buttons are blocked while still allowing for charging and limited audio port access. Constructed of high grade aluminum makes the Rokku Galaxy enclosure extremely lightweight and durable at the same time. With soft edges and rounded corners, the aesthetic of this enclosure is very appealing and fits all display environments.
The BrandMe stand allows you to utilize a panel for branding, call to action or custom design to bring attention to your interactive display or kiosk. The tilting mount allows the Galaxy enclosure to be set in either portrait or landscape mode and the stand base offers additional security features, securing the power source and bolting the unit to the floor.
Compulocks Rokku BrandMe - iPad 9.7" / Galaxy Tab A 9.7" / S2 9.7" / S3 9.7" Floor Stand - Black - stand
Stand - floor-standing
Recommended Use
Tablet
Apple iPad Air; iPad Air 2
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Floor-standing
Apple iPad Air , Apple iPad Air 2
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CSCG 036372
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £49.30
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Maclocks
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
