Lumens UXGA Digital Visual Gooseneck Presenter 1080p Full HD
Quicklinx: 8NDVWS00 Mfr#: DC265
  • SDHC Memory Card
The Lumens DC265 Ladibug is a high-definition multimedia document camera that delivers clear images and crisp text with a 6x optical zoom and 1080p, UXGA resolution, works seamlessly for all models with interactive whiteboards. One-touch audio/video recording and playback do not require a computer.
The Lumens DC265, the first portable visual presenter to offer six-time optical zoom and UXGA ultra-high resolution, delivers clear images and crisp text with unmatched functionality. Unique features, such as one-touch integrated audio and video recording, as well as seamless integration with interactive whiteboards, make this unit the perfect choice for educators. With true HDTV compatibility and other advanced connectivity capabilities, the DC265 is appropriate for both the current and future infrastructure of the school. Built on a powerful platform, this top of the line "Ladybug" strikes the perfect balance of usability and performance, making it an ideal multimedia presentation solution for K-12 educational use.
  • PC-free, one-touch operation
    Designed with educators in mind, the Lumens DC265 is intuitively simple to operate. The document camera can perform many key functions without additional software, thus reducing time spent turning on a PC or loading software. With the push of a button, teachers can record videos with synchronized audio, and then play back recorded demonstrations immediately. Other smart features, such as full-rotation capability, five-step book mode and a larger shooting area, allow teachers to position their materials under the camera, and quickly zoom to the desired area. As a result, educators can focus on the content rather than waste time re-shuffling and repositioning materials.
  • Capture students' attention
    With FastSlide technology, the DC265 features industry-best slide loading speed. Educators can be assured that they will capture students' attention without losing valuable teaching time to slides loading. Educators can also use the DC265 to capture images, take time-lapse photos, and create slide shows. In addition, built-in transition effects make presenting a professional-looking slide show instantaneous and effortless.
  • Integration with modern equipment
    The DC265 works seamlessly with modern classroom equipment, including interactive whiteboards, HD TVs, and projectors. It supports high-speed USB for transfer of real time presentations onto an interactive whiteboard. Teachers can now use the document camera to integrate materials and resources directly into their electronic curriculum. With an HDMI interface, and the ability to deliver the highest resolution in HDTV standard (1080p), the DC265 is truly HDTV-compatible. Its unique Dynamic Noise Reduction technology insures clear images on all DLP projectors.
  • Hassle-free maintenance
    Lumens' unique security features simplify equipment management and make it easier for schools to share equipment between several teacher-users. The DC265 comes with lock-down, wipe clean and auto back-up features. Lock-down prevents unauthorized usage, while the auto back up allows educators to easily and quickly copy images onto an SD card. The wipe clean option automatically deletes content between uses to ensure sensitive content remains controlled.
Lumens DC 265 Ladibug - digital document camera
Digital document camera
Audio
Yes: built-in microphone
21.1 cm x 43.2 cm x 55.9 cm
2.3 kg
Wired
Camera
Optical Zoom
6 x
Max Resolution
1600 x 1200
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS
Focus Adjustment
Automatic
USB 2.0, composite video, VGA, HDMI
1 - VGA cable - external , 1 - USB cable - external , 1 - audio cable - external , 1 - composite video cable - external , 1 - video adapter - external
Voltage
AC 120/230 V
Date/time stamp, digital image rotation, digital image freeze, auto exposure control, built-in LED lights, SDHC-card slot, dual cold-cathode lamp, picture-by-picture capability, auto white balance, digital image stabilisation (video mode)
5-year warranty
Audio Support
Wired
21.1 cm
43.2 cm
55.9 cm
2.3 kg
Camera
Max Digital Video Resolution
1600 x 1200
Digital Zoom
8
Frame Rate (max)
Still Image Capture Resolution
1600 x 1200, 1024 x 768, 1280 x 1024
Image Sensor
CMOS
Lens Construction
Optical Zoom
6 x
Focus Adjustment
Automatic
Video
Composite video, VGA, HDMI
Computer Interface
USB 2.0
Interfaces Details
1 x USB 2.0 , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x serial - RS-232 - 9 pin D-Sub (DB-9) , 1 x audio - line-out - mini-phone 3.5 mm , 2 x display / video - VGA output - 15 pin D-Sub (DB-15) , 1 x display / video - VGA input - 15 pin D-Sub (DB-15)
Supported Memory Cards
SDHC Memory Card
Microscope adapters, remote control
1 x VGA cable - external , 1 x USB cable - external , 1 x audio cable - external , 1 x composite video cable - external , 1 x video adapter - external
cUL, FCC, RoHS, WEEE
Power Requirements
AC 120/230 V
Power supply - internal AC 120/230 V
Software Included
Ladibug Software
Apple MacOS X, Microsoft Windows Vista / XP / 7
Limited warranty - replacement - 5 years
