Loxit Hi-Lo Mono Mobile LED/LCD Lift Max 130 Kg 84"
Quicklinx: CT38WS00 Mfr#: 8420
£1,009.66 ex VAT
£1,211.59 inc VAT
Get this single column wall to floor mounted electric screen lift. It is ideal for heavy duty electric operation with reinforced welded brackets for displays and touchscreens up to 84". Smooth electrical operation raises and lowers the screen, allowing all users access to the display.
  • Quality
    An elegant yet sturdy single column electric mobile lift with up to 600mm smooth electric lifting capacity. Equally suited to the boardroom as the classroom, it is constructed in the UK with precision engineering, built to last.
  • Universal
    Heavy duty electric lifting capacity with reinforced welded brackets easily mounts displays and touch screens up to 84" and 130kg. The quiet, smooth electrical operation raises and lowers the screen by 500 or 600mm, allowing perfect positioning of the display.
  • Easy install
    Easy install - arriving ready assembled, the Hi-Lo Mono trolley is a fast installation. Simply fix the hangers to the screen and mount onto the trolley.
  • No stress
    No stress - this trolley based electric screen mount allows the weight of the large format display or touch screen to be effortlessly lifted to the perfect height.
  • Power up
    Power up - includes integrated 4 way power strip and 3 IEC power outlets for the screen and peripherals with just one cable to the mains socket.
  • Cable managed
    Cable managed - cables are tidied away within the mount head and covered with the ventilated grille for a professional and safe installation.
LOXIT Hi-Lo Mono 500 Electric cart - for flat panel
Cart
Integrated Devices
Power strip, electric lift
78 cm x 70 cm x 126 cm
Lift
50 cm
58 kg
Recommended Use
Flat panel
Recommended Display Size
40"-84"
VESA Mounting Interface
Up to 800 x 440 mm
Max Load Weight
130 kg
Material
Aluminium, steel
5-year warranty
78 cm
70 cm
126 cm
58 kg
Material
Aluminium, steel
AV Furniture
Cart
Recommended Use
Flat panel
Up to 800 x 440 mm
Integrated Devices
40"-84"
Lift
50 cm
Max Load Weight
130 kg
Limited warranty - 5 years
Brand: Loxit
Price Range Ex VAT: £1000 - £1500
