These extension legs convert the LED/LCD wall mount into a floor mount where the weight of the screen is too great or the wall being fixed into is not strong enough to take the weight of the mount and screen.
- LOXIT mounting component - white powder coat
- Product Type
- Mounting component
- Mounting Components
- 2 legs
- 5 cm x 4 cm x 35 cm
- 4 kg
- White powder coat
- 5 cm
- 4 cm
- 35 cm
- 4 kg
- White powder coat
AV Furniture
- 2 legs
- Adjustable height
