Logitech Zone Wired MSFT Teams Headset Wired USB-C - Graphite
Quicklinx: GDR2WS00 Mfr#: 981-000870
Recommended Use: Computer, Portable electronics
Connectivity: Wired
Earcover : Binaural
18 In Stock
£111.00 ex VAT
£133.20 inc VAT
Hear and be heard clearly with a wired headset specifically designed for busy open workspaces.
The noise-canceling mic isolates your voice from the noise around you and the 40 mm audio drivers make calls as well as music sound great.
  • HEAR CALLS AND MUSIC CLEARLY
    Zone Wired is designed with generously-sized 40mm drivers to deliver pure happiness for your ears. Full-bodied bass, crisp higher frequencies and incredibly low distortion create a satisfying overall sound whether you're on a video call, listening to music, or toggling between the two. Go ahead, create your own audio bubble on your own terms with a wired headset that sounds great even in the busiest open workspaces
  • BE HEARD, DISTRACTION FREE
    Open workspaces are often noisy environments, both locally and for anyone you're chatting with on the other end of a call. Zone Wired solves the ambient noise issue with noise-canceling dual mic technology that accurately suppresses distracting sounds like keyboard clicks, nearby talkers, and HVAC noise as close as 60 cm away. By isolating your voice from any acoustic clutter around you, this USB headset delivers superbly clearer calls and video meetings
  • COLLABORATE IN STYLE
    Zone Wired is lightweight, stylish and designed for all-day use. The Teflon-coated stainless steel headband features a silicone head cushion and memory-foam ear pads that provide a comfortable fit throughout the workday. A braided cable adds durable mechanical strength, resists tangles, and is speckled with color for a contemporary, professional appearance
  • CERTIFIED FOR MICROSOFT TEAMS
    Microsoft Teams certification ensures it's super easy to launch the Teams 1 app directly from Zone Wired with a single click. Intuitive in-line controls are always at your fingertips on the tangle-free cable to adjust volume, mute, answer/end/reject calls, and play/pause music. The mic boom features a flip-to-mute function that provides immediate privacy any time and LED indicators on the controller provide at-a-glance confirmation of key functions
  • APP PROVIDES ADVANCED CONTROL
    Access Zone headset controls on your computer with Logi Tune for Desktop, a mini app that works unobtrusively on your screen for uninterrupted video collaboration. The app provides full EQ and sidetone control, quickly tests mic/speaker audio levels, and lets you set mic gain at whatever volume works best for you. Plus easily download firmware updates. This app is only available in the following languages: English, French, German, Italian, Spanish, and Portuguese
  • READY FOR BUSINESS
    Zone Wired works with common calling applications across most all platforms and operating systems. Business certifications include Microsoft Teams and Skype ? for Business, Certified for Google Meet and Voice. Compatible with integrated mute controls for Zoom and works with other popular applications like Cisco Jabber , BlueJeans, and GoToMeeting to ensure compatibility and seamless integration in the workplace
Logitech Zone Wired MSFT Teams - headset - USB-C
Headset - wired - USB-C
Compatibility
Windows
Recommended Use
Portable electronics, computer
Graphite
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 16000 Hz - Sensitivity 99 dB
Impedance
32 ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional, omni-directional
Microphones Included
2
Controls
Mute, volume, answer/end, play/pause, reject call
Software Certification
Certified for Microsoft Teams
Compatibility
Windows
17.973 cm
6.677 cm
16.593 cm
211 g
Graphite
Headband Material
Stainless steel, silicone
Earpad Material
Memory foam
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 16000 Hz
Sensitivity
99 dB
Impedance
32 ohm
Diaphragm
40 mm
In-Cord Volume Control
Microphone
Boom
Headset microphone
2
Sensitivity
-48 dBV/Pascal
Frequency Response
100 - 16000 Hz
Remote Control
Controls
Connector Type
Headset (USB Type-C)
Cable
Cable Length
1.9 m
Travel bag
Cable Details
Headset cable - anti tangle - 1.9 m , USB-C to USB-A adapter
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Binaural
Brand: Logitech
