Logitech Zone 305 -  Bluetooth - Wireless - USB-C via Bluetooth adapter-  Certified for MS Teams
Quicklinx: HT5QWS00 Mfr#: 981-001451
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
23 In Stock
£77.55 ex VAT
£93.06 inc VAT
This lightweight headset is ideal for employees who need great audio and a reliable long-range connection for uninterrupted calls.
  • Efficient noise-canceling
    Equipped with advanced beamforming and omnidirectional microphone technology, the Logitech Zone 305 headset ensures your voice is captured with clarity while minimizing background noise, making it ideal for both busy offices and quiet, focused spaces.
  • Superior connectivity
    Featuring Bluetooth 5.3 technology, this headset offers a stable and reliable wireless connection up to 30 m, allowing for freedom of movement without sacrificing audio quality. MultiPoint Technology enables simultaneous connection to two devices, seamlessly switching between your computer and portable electronics.
  • Comfortable design
    Designed with on-ear headphones that incorporate dynamic technology, the Zone 305 provides a comfortable fit for extended use. The headset is made from 55% post-consumer recycled plastic, aligning with eco-friendly practices without compromising on durability or quality.
  • Long-lasting battery life
    With a rechargeable lithium-ion battery that offers continuous talk and playback time, and a quick recharge time of just 2 hours, the Zone 305 headset is always ready when you are. A 5-minute quick charge delivers hours of use, ensuring you stay connected throughout the day.
  • Versatile compatibility
    The Logitech Zone 305 is designed to work seamlessly across a wide range of devices including Android phones, tablets, Chrome OS, Mac, Windows, iPads, and iPhones, making it a versatile choice for all your audio needs.
Logitech Zone 305 - headset - USB-C via Bluetooth adapter
Headset - Bluetooth - wireless - USB-C via Bluetooth adapter
Compatibility
iPhone, iPad, Android phone, Chrome OS, Mac, Windows, Android tablet
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear binaural
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 50 - 20000 Hz - Sensitivity 96 dB +/- 3dB
Impedance
32 Ohm
Noise Isolating
Microphone
Boom
Microphone Technology
Condenser
Microphone Operation Mode
Omni-directional, beamforming
Microphone Noise Cancelling
Microphones Included
2
Controls
Flip-to-mute
Environmental Standards
TCO Certified Headsets 9
Carbon Footprint
10.21 kg carbon emissions
Software Certification
Certified for Microsoft Teams, Works With Chromebook Certified
Compatibility
Dimensions & Weight Details
Headset: 16.67 cm x 6.6 cm x 17.28 cm / 122 g , Ear pad: 6.6 cm x 1.6 cm x 6.6 cm , USB-C receiver: 1.24 cm x 0.62 cm x 2.68 cm , USB-A adapter: 1.54 cm x 0.87 cm x 2.45 cm
16.67 cm
6.6 cm
17.28 cm
122 g
Body Material
Recommended Use
Max Operating Distance
30 m
Audio Output
On-ear binaural
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
50 - 20000 Hz
Sensitivity
96 dB +/- 3dB
Impedance
32 Ohm
Diaphragm
30 mm
Simultaneously Connectable Devices Qty
2
Audio Output Details
Multimedia - 50 - 20000 , Communication - 100 - 7000
Microphone
Boom
Headset microphone
Condenser
2
Frequency Response
100 - 7000 Hz
Noise Cancelling
Remote Control
Controls
Flip-to-mute
Carrying bag, USB-C charging cable, USB-C to USB-A adapter, USB-C receiver
Cable Details
USB-C charge cable - 1 m
FSC, CarbonNeutral, EN 50332-2
Sustainability Information
TCO Certified
Carbon Footprint
Headset battery rechargeable - Lithium Ion
Run Time (Up To)
20 hour(s)
Run Time Details
Continuous talk: up to 16 hours , Continuous playback: up to 20 hours , Continuous talk (with 5 min quick charge): up to 1 hour
Recharge Time
2 hour(s)
Recommended Use: Portable electronics
Brand: Logitech
