Logitech Z623 Speaker System
Speaker System Z623
Quicklinx: 7HSNWS00 Mfr#: 980-000404
Hurry, only 3 left in stock!
£113.09 ex VAT
£135.70 inc VAT
This THX-Certified 2.1 system delivers powerful sound with 200 watts (RMS) of power - for big, bold audio.
  • THX Certified
    These speakers have met strict performance standards to achieve THX certification - for quality you can count on
  • 200 watts (RMS) of power
    With 200 watts (RMS) of power, you can listen as loud as you want to. You'll hear - and feel - immersive audio that brings music, movies and games to life
  • Flexible connectivity
    RCA and 3.5 mm inputs, as well as a built-in headphone jack, make it easy to get great sound from up to three audio devices
  • Powerful 2.1 system
    Your powerful 2.1 system delivers easy, two-satellite setup and a powerful subwoofer for big sound - even in large spaces
  • Integrated controls
    You're in command with integrated controls - dial the volume and bass up or down to customise your listening experience
Logitech Z-623 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Audio System Peak Power (Total)
200 watt
Amplifier
Integrated
Speaker System Details
2 , 1 x subwoofer
Built-in Decoders
THX
Speaker System
System Components
Speaker Type
Active
200 watt
Amplifier
Integrated
Built-in Decoders
THX
Controls
Power on/off, volume, bass
Speakers Included
2 - wired , 1 x subwoofer - wired
Connector Type
2 x audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm)
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Subwoofer: 30.5 cm x 26.6 cm x 28.4 cm / 7 kg , Satellite speaker: 11.7 cm x 12.6 cm x 19.6 cm / 1 kg , Satellite speaker: 11.7 cm x 12.6 cm x 19.6 cm / 950 g
System Type: PC multimedia speaker system
Type: 2 speakers
Type: Subwoofer
Power: 200watt
Power: 200watt
Power: 200watt
Power: 200watt
Power: 200watt
Brand: Logitech
