Logitech Z553 Speaker System
Quicklinx: 8YTYWS00 Mfr#: 980-000650
You've got enough power to fill the room with bold, dynamic sound. A subwoofer with a 4-inch driver delivers deep lows for rich bass you can feel.
An RCA jack and two 3.5 mm auxiliary inputs let you easily connect up to 3 devices at the same time: PC, DVD player, game console, smartphone, and more.
  • 40 watts (RMS) of power
  • Down-firing subwoofer
  • Multiple connectivity
  • Convenient control pod
    Power, volume, and bass controls are within your reach with the wired control pod.
  • Small size, big versatility
    Optimize the look and sound of your setup with the compact, versatile design. Satellites sit on metal stands that can tilt up or down. Or if you prefer, mount them to the wall.
  • Logitech FDD² technology
    Enjoy fuller, richer sound thanks to Logitech's patented Frequency Directed Dual Drivers (FDD²) satellite technology.
Logitech Z-553 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
40 Watt
Frequency Response
55 - 17000 Hz
Amplifier
Integrated
Speaker System Details
2 x satellite speaker 10 Watt 4 Ohm , 1 x subwoofer 20 Watt 8 Ohm
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
40 Watt
Frequency Response
55 - 17000 Hz
Amplifier
Integrated
Controls
Power on/off, volume, bass
Speakers Included
2 x satellite speaker - 10 Watt - 4 Ohm - wired , 1 x subwoofer - 20 Watt - 8 Ohm - wired
Driver Details
Satellite speaker: full-range driver - 2" - Frequency Directed Dual Driver (FDD2)
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 4"
Connector Type
2 x audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2)
Audio cable, remote control
Remote Control
Remote control - cable
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Satellite speaker: 9 cm x 13.7 cm x 16 cm , Subwoofer: 38.1 cm Diameter 16 cm
