Logitech Z337 2.1-channel Wireless Bluetooth Speaker System
Quicklinx: DNT8WS00 Mfr#: 980-001262
Enjoy the convenience of wireless streaming and never worry about battery life because this 2.1 speaker system is always plugged in. Its 80 Watts Peak/40 Watts RMS power delivers bold sound. Easily access the Bluetooth pairing button from the wired control pod. Adjust the bass level with the dedicated control knob on the back of the subwoofer. For a wired connection use the 3.5mm or RCA inputs.
  • Wireless audio via Bluetooth
    Stream audio wirelessly from any Bluetooth device by connecting your computer, smartphone or tablet via the pairing button conveniently located on the control pod
  • 80 Watts of Bold Sound
    80 Watts Peak/40 Watts RMS power delivers maximum loudness via two satellite speakers and a large subwoofer. Enjoy rich, clear, bold sound
  • Strong bass
    The front-facing subwoofer produces rich bass, adding another dimension to your videos, games and music. Experience strong bass you can hear and feel
  • Wired connection
    For a wired connection use the 3.5mm or RCA inputs. No need to disconnect or re-pair when switching between audio sources
  • Simple controls
    Easily access Bluetooth pairing, power, volume and the headphone jack from the wired control pod. Adjust the bass level with the dedicated control knob on the back of the subwoofer
Logitech Z337 - speaker system - wireless
Speaker system - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
40 watt
Audio System Peak Power (Total)
80 watt
Amplifier
Integrated
Bluetooth
Speaker System Details
1 x subwoofer 24 watt , 2 x satellite speaker 8 watt
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
40 watt
80 watt
Amplifier
Integrated
Bluetooth 4.1
Transmission Range
15 m
Controls
Power on/off, volume, bass
Headphone Output Jack
Speakers Included
1 x subwoofer - 24 watt - wired , 2 x satellite speaker - 8 watt - wired
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm)
Audio cable, wired remote control
Dimensions (WxDxH) / Weight Details
Satellite speaker: 10.8 cm x 9 cm x 19.28 cm / 640 g , Subwoofer: 23.2 cm x 15.7 cm x 23 cm / 2.4 kg , Control unit: 5.4 cm x 5.5 cm x 5.5 cm / 72 g
