This 2.1 speaker system delivers maximum loudness and produces rich bass from the front-facing subwoofer. Connect up to two compatible devices via the 3.5 mm and RCA inputs. The wired control pod provides simple controls.
80 Watts of Bold sound
80 Watts Peak/40 Watts RMS power delivers maximum loudness via two satellite speakers and a large subwoofer. Enjoy rich, clear, bold sound -
Strong bass
The front-facing subwoofer produces rich bass, adding another dimension to your videos, games and music. Experience strong bass you can hear and feel -
Versatile setup
Connect up to two compatible devices via the 3.5mm and RCA inputs. No need to disconnect when switching between audio sources -
Simple controls
Easily access power, volume and the headphone jack using the wired control pod. Adjust the bass level with the dedicated control knob on the back of the subwoofer
- Logitech Z333 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker , 1 x subwoofer
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Amplifier
- Integrated
- Controls
- Power on/off, volume, bass
- Speakers Included
- 2 x satellite speaker - wired , 1 x subwoofer - wired
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Wired remote control with headphones connector
- Power Source
- AC power adapter
