Logitech Z313 2.1 Channel Multimedia Speaker System - 25 Watt
Speaker System Z313
Quicklinx: 7480WS00 Mfr#: 980-000447
Hurry, only 1 left in stock!
£39.67 ex VAT
£47.60 inc VAT
With a convenient control pod and big, balanced sound, this speaker system is the easy way to kick back with your music.
Convenient control pod
Volume and power controls are within your reach with the wired control pod.
25 watts (RMS)
You've got enough power to fill your room with big, balanced sound.
Compact subwoofer
The compact, high-excursion subwoofer fits into tight spaces and delivers deeper bass when you want to feel the beat
Easy setup
You just connect the speakers to the subwoofer, and plug the subwoofer into your computer. That's it
Headphone jack
You can listen to your favorite tracks, play games, and watch videos in private.
  • Rich Sound
    50 Watts Peak/25 Watts RMS power delivers a full range of sound tuned for balanced acoustics. Enhanced bass is delivered by the compact subwoofer. Enjoy a rich audio experience straight out-of-the-box
  • Simple Setup
    Connect any device via the 3.5mm input. Simple setup; always great sound
  • Easy Controls
    Easily access power, volume and the headphone jack using the wired control pod
  • Control at hand
    You've got power-and volume-in the palm of your hand with the wired control pod
  • Get down on it
    Say good-bye to built-in PC audio. You get room-filling sound and deeper bass for all your PC entertainment
  • Strike a pose
    You can put this sleek system anywhere in your room-it complements your setup and your style
Logitech Z-313 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
25 Watt
Audio System Peak Power (Total)
50 Watt
Frequency Response
48 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 , 1 x subwoofer
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
25 Watt
50 Watt
Frequency Response
48 - 20000 Hz
Amplifier
Integrated
Controls
Volume
Speakers Included
2 - wired , 1 x subwoofer - wired
Remote control
Remote Control
Remote control - cable
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
8.1 cm x 8.9 cm x 14.6 cm , Subwoofer: 22 cm x 15 cm x 22.8 cm
System Type: PC multimedia speaker system
Type: 2 speakers
Type: Subwoofer
Power: 25watt
Brand: Logitech
