Logitech Z150 Multimedia Speakers - Midnight Black
Quicklinx: BGXTWS00 Mfr#: 980-000816
Type: 2 speakers
Power: 3Watt
£18.27 ex VAT
£21.92 inc VAT
These twin 2.0 dual input multimedia speakers allow 3 watts of clear stereo sound. Their control is simple and convenient with integration of volume and power. The Z150 includes a handy headphone jack for your private listening pleasure.
  • Clear Stereo Sound
    6 Watts Peak/3 Watts RMS power delivers clear stereo sound from the dual 2" driver design
  • Headphone Jack
    Simply plug your headphones into the easily accessible jack located on the front of the right speaker
  • Easy Controls
    Easily access power, volume, headphone jack and auxiliary jack on the right speaker
Logitech Z150 - speakers - for PC
Speakers - for PC
United Kingdom
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
3 Watt
Audio System Peak Power (Total)
6 Watt
Amplifier
Integrated
Speaker System Details
2 x speaker 1.5 Watt
8.45 cm x 7.6 cm x 15.15 cm
583 g
Speakers - for PC
Enclosure Colour
United Kingdom
Speaker System
System Components
2 speakers
Speaker Type
Active
Audio System Continuous Power (Total)
3 Watt
6 Watt
Amplifier
Integrated
Controls
Power on/off, volume
Speakers Included
2 x speaker - 1.5 Watt - wired
Driver Details
Speaker: full-range driver - 2"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
Power adapter
Power Source
AC power adapter
8.45 cm
7.6 cm
15.15 cm
583 g
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: BGXT 051131
Condition: Customer return - item has been used and shows signs of use/ damaged box
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £12.66
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: 2 speakers
Power: 3Watt
Brand: Logitech
Stock Status: Used Stock
