These twin 2.0 dual input multimedia speakers allow 3 watts of clear stereo sound. Their control is simple and convenient with integration of volume and power. The Z150 includes a handy headphone jack for your private listening pleasure.
Clear Stereo Sound
6 Watts Peak/3 Watts RMS power delivers clear stereo sound from the dual 2" driver design -
Headphone Jack
Simply plug your headphones into the easily accessible jack located on the front of the right speaker -
Easy Controls
Easily access power, volume, headphone jack and auxiliary jack on the right speaker
- Logitech Z150 - speakers - for PC
- Product Type
- Speakers - for PC
- Localisation
- United Kingdom
- System Components
- 2 speakers
- Speaker Type
- Active
- Nominal Output Power (Total)
- 3 Watt
- Audio System Peak Power (Total)
- 6 Watt
- Amplifier
- Integrated
- Speaker System Details
- 2 x speaker 1.5 Watt
- Black
- 8.45 cm x 7.6 cm x 15.15 cm
- 583 g
- 2-year warranty
- Product Type
- Speakers - for PC
- Enclosure Colour
- Black
- Localisation
- United Kingdom
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 3 Watt
- 6 Watt
- Amplifier
- Integrated
- Controls
- Power on/off, volume
- Speakers Included
- 2 x speaker - 1.5 Watt - wired
- Driver Details
- Speaker: full-range driver - 2"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Power adapter
- Power Source
- AC power adapter
- 8.45 cm
- 7.6 cm
- 15.15 cm
- 583 g
- Limited warranty - 2 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
BGXT 051131 Condition: Customer return - item has been used and shows signs of use/ damaged box |
£8.35 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
