Get rich stereo sound in a small package. Simple to set up and control, these speakers make it easy to enjoy your music, movies and games.
Rich stereo sound
With five watts of total power, you get sound that's clear and strong.
Easy to control
It's a snap to get the sound you want with simple volume and power controls.
Built-in headphone jack
Plug in your headphones and listen to your music, movies and games where and when you want to.
Simple setup
Just connect the speakers to your laptop with a standard 3.5 mm plug and you're ready to go.
Full Stereo Sound
10W Peak/5W RMS power delivers clear stereo sound and strong bass -
Strong Bass
Front-facing reflex port provides extra bass to your audio experience -
Easy Controls
Easily access power, volume and headphone jack on the right speaker -
Rich, clear sound
5 watts of total power means you get strong stereo sound from these speakers -
Easy setup
Just connect the speakers to your laptop with a standard 3.5 mm plug and you're ready to go -
Your way
A headphone jack and convenient volume controls let you listen to your music, movies and games on your terms
- Logitech Z-130 - speakers - for PC
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- Active
- Nominal Output Power
- 5 Watt
- Amplifier
- Integrated
- Speaker System Details
- 2 2.5 Watt
- 10.1 cm x 11 cm x 14.2 cm
- 0.59 kg
- 2-year warranty
- Product Type
- Speakers - for PC
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- 5 Watt
- Amplifier
- Integrated
- Controls
- Volume
- Speakers Included
- 2 - 2.5 Watt - wired
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, speaker cable kit
- Power Source
- AC power adapter
- 10.1 cm
- 11 cm
- 14.2 cm
- 0.59 kg
- Limited warranty - 2 years
