Logitech Z-906 5.1 Surround Sound Speakers
Quicklinx: 7KBCWS00 Mfr#: 980-000469
16 In Stock
£272.82 ex VAT
£327.38 inc VAT
This THX-Certified 5.1 system delivers 500 watts (RMS) of theater-quality sound. Digital and analog inputs, an easy-to-read-and-stack control console and a wireless remote let you take charge of your entertainment.
500-watts (RMS) of power
Make any night opening night. You get thunderous audio that can shake your house--and your whole neighborhood
THX® Certified
You've got quality you can count on--these speakers have met strict performance standards to achieve THX certification.
Digital decoding
Hear every detail all around you--from the roar of the crowd to the footsteps right behind you--in your Dolby digital or DTS encoded soundtracks.
Digital and analogue inputs
You've got the flexibility to set up your system the way you want to. Connect up to six audio sources, including your TV, Blu-ray™/DVD player, DVR, Xbox 360®, PLAYSTATION®3, Wii™; iPod; PC and more.
Easy-to-read control console
The stackable, easy-to-read design fits in with your home-entertainment system and gives you control of your audio--change the volume on all your speakers, turn the power on or off, set inputs and more.
Wireless remote
You can control your listening experience without ever getting off the couch.
Wall-mountable satellites
Let you transform any room into a home theatre.
Surround sound with 3D Stereo
Your speakers convert two-channel stereo into an immersive surround sound experience.
Ported, side-firing subwoofer
165 watts of deep bass brings your music, movies and games to life.
  • 500 watts (RMS) of power
    500 watts (RMS) of power let you make any night opening night and deliver thunderous audio that can shake your house-and your whole neighbourhood
  • THX Certified
    These speakers have met strict performance standards to achieve THX certification-so you can be sure that your entertainment will sound the way it was meant to sound
  • Digital decoding
    Digital decoding enables detailed surround sound-from the roar of the crowd to the footsteps right behind you-in your Dolby digital or DTS encoded soundtracks
  • Multiple inputs
    Multiple inputs allow you to connect up to six components simultaneously and set up your system the way you want to. Connect your TV, Blu-ray /DVD player, DVR, Xbox 360 , PLAYSTATION 3, Wii , iPod , stereo and more
  • Control console and wireless remote
    You're in command with the control console and wireless remote-select inputs and adjust surround sound and volume levels to customise your listening experience
Logitech Z-906 - speaker system - for home theatre
Speaker system - for home theatre - 5.1-channel
System Components
Control unit, 5 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
500 Watt
Speaker System Details
4 x surround channel speaker 67 Watt , 1 x centre channel speaker 67 Watt , 1 x subwoofer 165 Watt
Built-in Decoders
Dolby Digital, DTS decoder
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
500 Watt
THX certified
Built-in Decoders
Speakers Included
4 x surround channel speaker - 67 Watt - wall-mountable - wired , 1 x centre channel speaker - 67 Watt - wall-mountable - wired , 1 x subwoofer - 165 Watt - wired
Connector Type
2 x SPDIF input (TOS Link) , SPDIF input (RCA) , Digital 5.1 channel audio line-in , Audio line-in (RCA x 2) , Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, remote control, speaker cable kit
Remote Control
Remote control - infrared
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Subwoofer: 28.1 cm x 31.9 cm x 29.3 cm / 9 kg , Centre channel speaker: 16.63 cm x 9.35 cm x 10.03 cm / 890 g , Satellite speaker: 10.03 cm x 9.35 cm x 16.63 cm / 890 g , Control unit: 29.3 cm x 28.1 cm / 500 g
System Type: Home theatre speaker system
Type: 5 speakers
Type: Control unit
Type: Subwoofer
Power: 500Watt
Brand: Logitech
