Logitech Z 5500 Digital - PC multimedia home theatre speaker system - 505 Watt (Total)
Z-5500 Digital 5.1 Speaker System
Customer rating: 5.0* (Write a review)
Quicklinx: 3TM3WS00 Mfr#: 970115-0120
Logitech has taken its award-winning Z-680 speaker system and made it even better. How? By improving everything from the subwoofer to the satellites and adding new innovations like real-time digital sound equalization.
The result is the Logitech Z-5500 Digital, a THX-certified, 505-watt 5.1 surround sound speaker system that offers everything you could possibly want... and some things you didn't even know you needed. And once you plug in your PC, DVD or music player, or video game console, you'll never want to listen to anything else.
Many call the Z-5500 Digital speakers the best multimedia system ever. 505-watt RMS and a deep note 25.4 cm (10") subwoofer deliver thundering power, THX-certified, high fidelity, theatre-quality sound. You can simultaneously connect up to 6 audio sources (PCs, video game consoles and DVD/CD/portable music players). Innovative satellite design with removable cloth grilles and rotating pedestals allow desk placement or wall-mounting, so you can transform any room into a home theatre.
Logitech Z-5500 Digital - speaker system - for PC
Speaker system - for PC - 5.1-channel
System Components
Signal process unit, 5 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
505 Watt
Audio System Peak Power (Total)
1010 Watt
Frequency Response
33 - 20000 Hz
Nominal Impedance
8 kOhm
Amplifier
Integrated
Speaker System Details
1 x subwoofer 188 Watt , 1 x centre channel speaker 69 Watt , 4 x satellite speaker 62 Watt
Built-in Decoders
Dolby Pro Logic II, DTS 96/24, Dolby Digital, DTS decoder
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
505 Watt
1010 Watt
Frequency Response
33 - 20000 Hz
Nominal Impedance
8 kOhm
Signal-To-Noise Ratio
100 dB
Max Output Level (Max SPL)
115 dB
THX certified
Amplifier
Integrated
Built-in Decoders
Controls
Input selector, mute, subwoofer volume control, rear volume control, centre volume control, power on/off, volume
Detachable Grilles
Speakers Included
1 x subwoofer - 188 Watt - wired , 1 x centre channel speaker - 69 Watt - wired , 4 x satellite speaker - 62 Watt - wired
Driver Details
Satellite speaker: full-range driver - 3" - aluminium
Driver Details (2nd speaker)
Centre channel speaker: full-range driver - 3"
Driver Details (3rd speaker)
Subwoofer: subwoofer driver - 10"
Connector Type
SPDIF input (RCA) , SPDIF input (TOS Link) , Digital 5.1 channel audio line-in (mini-phone stereo 3.5mm x 3) , Audio line-in (mini-phone stereo 3.5 mm)
Remote control, aerial cable kit
Remote Control
Remote control - infrared
Power Source
AC power adapter
Customer reviews
Write a review for the Logitech Z 5500 Digital - PC multimedia home theatre speaker system - 505 Watt (Total) here!
Logitech Z-5500 5.1 Speakers
Reviewed by Martyn. Lockhart. Review Posted 12/03/2006
Ordered 6.30pm,got the next day,Dabs came up trumps yet again. Well as far as this review goes,what can i say except does exectly what it says on the box EEEEEHHHHHHHAAAAAAAA !!!! :D
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Wow, great but huge
Reviewed by Bob Foster. Review Posted 26/01/2008
The ability to connect my Digi Box and PC to the same set of 5.1 speakers led me to this product, but I didn't expect such good sound quality. Yes, the Sub is huge, but it is attractive and becomes part of the furniture. I like the fact that they use proper speaker cable, so I can buy extra and wire it behind the skirting board when I get time. For the person wanting to move the control unit further away from the sub - it is just a standard VGA connector, and Dabs do an extension cable. Works a treat. As usual Dabs were great. All in all I can't think of a better solution to me sound needs.
  • Overall 5*
  • Ease of use 5*
Fantastic Speakers
Reviewed by Sam Thompson. Review Posted 02/06/2008
Great set of speakers at an amazing price. Arrived very quickly as usual with dabs (2 days!). Took me a while to wire this up, but it was well worth it in the end. I have it hooked up to my Playstation 3 using a digital optical cable, bought at the same time (quicklinx: 3B48DM). GTAIV is a totally different experience now!
  • Overall 5*
  • Ease of use 5*
Read all 25 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
