Logitech has taken its award-winning Z-680 speaker system and made it even better. How? By improving everything from the subwoofer to the satellites and adding new innovations like real-time digital sound equalization.
The result is the Logitech Z-5500 Digital, a THX-certified, 505-watt 5.1 surround sound speaker system that offers everything you could possibly want... and some things you didn't even know you needed. And once you plug in your PC, DVD or music player, or video game console, you'll never want to listen to anything else.
Many call the Z-5500 Digital speakers the best multimedia system ever. 505-watt RMS and a deep note 25.4 cm (10") subwoofer deliver thundering power, THX-certified, high fidelity, theatre-quality sound. You can simultaneously connect up to 6 audio sources (PCs, video game consoles and DVD/CD/portable music players). Innovative satellite design with removable cloth grilles and rotating pedestals allow desk placement or wall-mounting, so you can transform any room into a home theatre.
- Logitech Z-5500 Digital - speaker system - for PC
- Product Type
- Speaker system - for PC - 5.1-channel
- System Components
- Signal process unit, 5 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 505 Watt
- Audio System Peak Power (Total)
- 1010 Watt
- Frequency Response
- 33 - 20000 Hz
- Nominal Impedance
- 8 kOhm
- Amplifier
- Integrated
- Speaker System Details
- 1 x subwoofer 188 Watt , 1 x centre channel speaker 69 Watt , 4 x satellite speaker 62 Watt
- Built-in Decoders
- Dolby Pro Logic II, DTS 96/24, Dolby Digital, DTS decoder
- 2-year warranty
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 505 Watt
- 1010 Watt
- 33 - 20000 Hz
- Nominal Impedance
- 8 kOhm
- Signal-To-Noise Ratio
- 100 dB
- Max Output Level (Max SPL)
- 115 dB
- THX certified
- Amplifier
- Integrated
- Built-in Decoders
- Controls
- Input selector, mute, subwoofer volume control, rear volume control, centre volume control, power on/off, volume
- Detachable Grilles
- Speakers Included
- 1 x subwoofer - 188 Watt - wired , 1 x centre channel speaker - 69 Watt - wired , 4 x satellite speaker - 62 Watt - wired
- Driver Details
- Satellite speaker: full-range driver - 3" - aluminium
- Driver Details (2nd speaker)
- Centre channel speaker: full-range driver - 3"
- Driver Details (3rd speaker)
- Subwoofer: subwoofer driver - 10"
- Connector Type
- SPDIF input (RCA) , SPDIF input (TOS Link) , Digital 5.1 channel audio line-in (mini-phone stereo 3.5mm x 3) , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Remote control, aerial cable kit
- Remote Control
- Remote control - infrared
- Power Source
- AC power adapter
- Limited warranty - 2 years
Customer reviews
Write a review for the Logitech Z 5500 Digital - PC multimedia home theatre speaker system - 505 Watt (Total) here!
Logitech Z-5500 5.1 Speakers
Reviewed by Martyn. Lockhart. Review Posted 12/03/2006
Ordered 6.30pm,got the next day,Dabs came up trumps yet again. Well as far as this review goes,what can i say except does exectly what it says on the box EEEEEHHHHHHHAAAAAAAA !!!! :D
Overall
Ease of use
Value for money
Wow, great but huge
Reviewed by Bob Foster. Review Posted 26/01/2008
The ability to connect my Digi Box and PC to the same set of 5.1 speakers led me to this product, but I didn't expect such good sound quality. Yes, the Sub is huge, but it is attractive and becomes part of the furniture. I like the fact that they use proper speaker cable, so I can buy extra and wire it behind the skirting board when I get time. For the person wanting to move the control unit further away from the sub - it is just a standard VGA connector, and Dabs do an extension cable. Works a treat. As usual Dabs were great. All in all I can't think of a better solution to me sound needs.
Overall
Ease of use
Value for money
Fantastic Speakers
Reviewed by Sam Thompson. Review Posted 02/06/2008
Great set of speakers at an amazing price. Arrived very quickly as usual with dabs (2 days!). Took me a while to wire this up, but it was well worth it in the end. I have it hooked up to my Playstation 3 using a digital optical cable, bought at the same time (quicklinx: 3B48DM). GTAIV is a totally different experience now!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
