Logitech Z 2300 - PC multimedia speaker system - 200 Watt (Total)
Z-2300 2.1 Speaker System
Customer rating: 5.0* (Write a review)
Quicklinx: 3TM4WS00 Mfr#: 970118-0120
If you love music, you'll love the Logitech Z-2300, a 2.1 speaker system that combines everything you need in a sound system: THX -certified performance and quality, beautiful looks, and more than enough power to fill your room with great sound.
Logitech Z-2300 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
200 Watt
Frequency Response
35 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 40 Watt , 1 x subwoofer 120 Watt
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
200 Watt
Frequency Response
35 - 20000 Hz
Signal-To-Noise Ratio
100 dB
THX certified
Amplifier
Integrated
Controls
Subwoofer volume control, volume
Detachable Grilles
Speakers Included
2 - 40 Watt - wired , 1 x subwoofer - 120 Watt - wired
Driver Details
Satellite speaker: full-range driver - 2.5"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 8"
Connector Type
Headphones
Audio cable kit, remote control, audio adapter
Remote Control
Remote control - cable
Power supply - internal
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
8.9 cm x 15.2 cm x 17.1 cm , Subwoofer: 28 cm x 38 cm x 28 cm
Customer reviews
Write a review for the Logitech Z 2300 - PC multimedia speaker system - 200 Watt (Total) here!
AMAZING!!!
Reviewed by GkB. Review Posted 09/01/2009
Easily one of the best 2.1 systems out there!
Super Loud when you need it and the Bass is unbelivable!
WOrd of Warning! I bought these speakers while in student halls and within 2 months there were threts of ASBOS for the noise! You could only hear it 3 streets up:P
AMAzing Buy!! Dont waste you time and money with any other speakers out there!
Amazing!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Awesome
Reviewed by William le Gros. Review Posted 07/01/2009
Still Perfect Since the Day I first Saw them on the Internet, Years of Use and Now Sound Quality Loss, To Put them on Full though is for the More Suicidal Eared Folk out there :)
Just Look in Awwwwwwweee at them and Their Mighty Box, Which I still Have used twice for moving house, Its Big enough to put Most kids in :)
  • Overall 5*
  • Ease of use 5*
Sound quality
Reviewed by David. Review Posted 12/12/2007
The sub is just obscene; outputs enough bass to turn my uni common room into some kind of disco, but the satellites are somewhat lacking in comparison, and you can hear when you start to drive them too hard. They do best on electronic music and film soundtracks, where there is a heavy low frequency presence, and worst on piano or other mid range heavy sound with great dynamic range, where distortion can be heard on the fortissimo midrange at high volume.
You really need to apply a small amount of EQ work to these, since they have a resonance at around 100-150HZ - dropping this frequency by 3db on windows media player will do the trick for most users.
Volume is just enough to play music over my drum kit,
  • Overall 5*
  • Ease of use 5*
Read all 17 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
