This mobile wireless speaker ensures crystal clear sound and is perfect for life on the go!
Rocking sound
Crystal clear sound. Pump up the volume and enjoy! -
Connect and play
Wirelessly connect, stream music, manage phone calls and control volume -
Take it anywhere
Perfect for life on the go. Take it on the road or relax and listen at home -
Design
In five bold colors, this unique design is sure to turn some heads -
5 hour Battery
Enjoy 5 hours of continuous play without recharging. Recharge the built-in lithium-ion battery with the convenience of the included micro-USB cable and rock on
- Logitech X100 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 1 x portable speaker 3 Watt
- Red
- Power Options
- USB powered
- Battery
- Speaker battery rechargeable - Lithium Ion
- 9.6 cm
- 162 g
- Product Type
- Hands-Free Function
- Enclosure Colour
- Red
Speaker System
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- Amplifier
- Integrated
- Bluetooth
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume
- Speakers Included
- 1 x portable speaker - 3 Watt - wireless
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Mini-USB cable
- Power Source
- Battery
- Options
- USB powered
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 5 hour(s)
- 9.6 cm
- 162 g
