Logitech X100 Mobile Wireless Speaker - Red
Quicklinx: BKWJWS00 Mfr#: 984-000366
This mobile wireless speaker ensures crystal clear sound and is perfect for life on the go!
  • Rocking sound
    Crystal clear sound. Pump up the volume and enjoy!
  • Connect and play
    Wirelessly connect, stream music, manage phone calls and control volume
  • Take it anywhere
    Perfect for life on the go. Take it on the road or relax and listen at home
  • Design
    In five bold colors, this unique design is sure to turn some heads
  • 5 hour Battery
    Enjoy 5 hours of continuous play without recharging. Recharge the built-in lithium-ion battery with the convenience of the included micro-USB cable and rock on
Logitech X100 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Continuous Power
3 Watt
Amplifier
Integrated
Bluetooth
Speaker System Details
1 x portable speaker 3 Watt
Red
Power Options
USB powered
Speaker battery rechargeable - Lithium Ion
9.6 cm
162 g
Hands-Free Function
Enclosure Colour
Red
Speaker System
Speaker Type
Active
Continuous Power
3 Watt
Amplifier
Integrated
Bluetooth
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
Transmission Range
10 m
Controls
Power on/off, volume
Speakers Included
1 x portable speaker - 3 Watt - wireless
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Mini-USB cable
Power Source
Options
USB powered
Rechargeable - Lithium Ion
Run Time (Up To)
5 hour(s)
9.6 cm
162 g
