Plug the Logitech X-530 into your PC, music player, DVD player, or even your PlayStation or Xbox game console and immerse yourself in clean, crisp, consistent surround sound from your games, movies, and more. The high-tech subwoofer adjusts itself dynamically to deliver distortion-free bass. And the five wall-mountable satellite speakers use Logitech's patented FDD2 technology to eliminate the uneven sound response created by conventional dual-driver designs. The result: a clear, uniform sound field without the "hot spots" and inconsistency of other dual-driver satellites.
Balanced, intense sound
Each speaker houses two drivers (or Frequency Directed Dual Driver technology)--the result is balanced, intense sound from anywhere in your room.
5.1 speaker system A surround sound system with speakers in front of and behind you to immerse you in your entertainment. It includes left and right front speakers, left and right rear speakers, a front center speaker, and a subwoofer. If you're into movies or gaming, this is the perfect choice for you.
5.1 surround sound
Matching front and rear satellites give you balanced surround sound, while a dedicated center channel makes dialog clear and intelligible.
Most home surround sound systems are 5.1 systems. Five speakers and a subwoofer immerse you in your entertainment. Your front left and right satellite speakers deliver the soundtrack and most special effects. Dialog and vocals come from the center channel--making it seem as if they're coming straight out of the screen. The left and right surround speakers add ambient sounds and more special effects from behind you. And the subwoofer brings in the booming bass. All of that means a tank can drive past you, rain can pour down in every direction, or a concert can sound like it's happening all around you. All in the comfort of your home.
Real-time bass equalisation
Equalization gives you more bass response with less distortion.
Ported subwoofer design
A subwoofer with 5.25-inch (13.3 cm) drivers let you enjoy deeper bass thanks to greater air displacement
Headphone jack
When you want to listen privately, you just plug in your headphones.
Convenient controls
Master volume and subwoofer level controls give you quick, convenient access right from the speakers.
Wall-mountable satellites
You simply rotate the stands of your adjustable satellite speakers to switch from desktop to wall.
- Logitech X-530 - speaker system - for PC
- Product Type
- Speaker system - for PC - 5.1-channel
- Localisation
- English / United Kingdom
- System Components
- 5 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 70 Watt
- Audio System Peak Power (Total)
- 140 Watt
- Frequency Response
- 40 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 7.4 Watt , 2 7.4 Watt , 1 x centre channel speaker 15.5 Watt , 1 x subwoofer 25 Watt
- Power
- AC 240 V
- 2-year warranty
- Product Type
- Localisation
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 70 Watt
- 140 Watt
- 40 - 20000 Hz
- Signal-To-Noise Ratio
- 96 dB
- Amplifier
- Integrated
- Recommended Placing
- Wall-mountable
- Controls
- Subwoofer volume control, volume
- Speakers Included
- 2 - 7.4 Watt - wired , 2 - 7.4 Watt - wired , 1 x centre channel speaker - 15.5 Watt - wired , 1 x subwoofer - 25 Watt - wired
- Driver Details
- Satellite speaker: 2 x high/midrange driver - 2" - Frequency Directed Dual Driver (FDD2)
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 5.25"
- Connector Type
- Headphones
- Included Accessories
- Power adapter
- Power Device
- Power adapter
- Power Source
- AC power adapter
- Voltage Required
- AC 240 V
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 6.4 cm x 7.6 cm x 20.3 cm , Subwoofer: 15.2 cm x 23.5 cm x 22.9 cm
- Limited warranty - 2 years
Customer reviews
Write a review for the Logitech X 530 - 5.1-channel PC multimedia home theatre speaker system - 70 Watt (Total) here!
Good speakers
Reviewed by Chris C. Review Posted 04/06/2008
Run perfectly well off my old (5 years) Creative 5.1 sound card (you need the three outs F/M/R). More bass than you can shake a stick at and the cables are long enough for a bedroom or home office. Excellent price. Integrated amp in the subwoofer drives all five speakers using phono cables.
Overall
Ease of use
Value for money
Logitech X-530 5.1
Reviewed by Brian Yeo. Review Posted 01/12/2007
I have really enjoyed the experience of having the Logitech 5.1 surround system on my pc and my dvd player. The value is outstanding. When I originally bought them I was a tad sceptical as the value was just a little more than a good set of headhpones. Well my whole family enjoy these speakers as we can move them around with ease from pc to pc or even the Dvd player so we can all watch a film in 5.1. My son even uses it on his playstation. They are all plug and play. Excellent is my view.
Overall
Ease of use
Value for money
Reviewed by . Review Posted 10/09/2006
Excellent value for money. I even bought a second set so I have them in my bedroom and front room.
Games, DVD's and music all sound really good with these speakers.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
