Logitech X 210 - 2.1-channel PC multimedia speaker system - 25 Watt (Total)
X210
Quicklinx: 7S6RWS00 Mfr#: 970191-0120
Pump up your PC, CD and MP3 audio with Logitech's X-210 speaker system. Its sleek compact satellites with high-excursion drivers provide full, rich sound. The ported subwoofer design features dynamic, real-time equalization that maximizes bass response while minimizing distortion. It also displaces more air for deeper bass. The X-210 speaker system also has a convenient wired remote with volume and power controls and a headphone jack for private listening. Satellite speaker stands rotate for easy wall mounting. Plug and play connects easily to PCs, CD and MP3 players.
Box Contents
- Logitech X210 2.1 Speakers
- 2 Satellites
- Subwoofer
- Color-coded Audio Cables
- User's Manual
- 2-year Limited Warranty
  • Immersive audio experience
    The Logitech X-210 speaker system delivers a rich, immersive audio experience with its 2.1-channel configuration, combining two full-range drivers and a powerful subwoofer to fill any room with dynamic, high-quality sound.
  • Versatile connectivity
    Equipped with a mini-phone stereo 3.5 mm connector, the Logitech X-210 allows for easy connection to a wide range of devices, ensuring your favorite music, games, and videos sound better than ever.
  • Convenient control
    With an integrated amplifier and cable remote control technology, the Logitech X-210 speaker system puts the power at your fingertips, allowing you to easily adjust volume and power on/off without interrupting your audio experience.
Logitech X-210 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
25 Watt
Audio System Peak Power (Total)
50 Watt
Frequency Response
48 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 5 Watt , 1 x subwoofer 15 Watt
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
25 Watt
50 Watt
Frequency Response
48 - 20000 Hz
Amplifier
Integrated
Controls
Power on/off, volume
Speakers Included
2 - 5 Watt - wired , 1 x subwoofer - 15 Watt - wired
Driver Details
Full-range driver - 2"
Driver Details (2nd speaker)
Subwoofer: woofer driver - 4"
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Audio line-in (mini-phone stereo 3.5 mm)
Audio cable kit, remote control
Remote Control
Remote control - cable
Power supply - internal
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
6.4 cm x 7.6 cm x 15.2 cm , Subwoofer: 15.2 cm x 22.9 cm x 21.6 cm
