Brand
Logitech Wireless Touch Keyboard K400 Plus Wireless 2.4 GHz - White
Quicklinx: F9WYWS00 Mfr#: 920-007144
Wired / Wireless: Wireless
Compatibility: PC
22 In Stock
£35.78 ex VAT
£42.93 inc VAT
Experience PC-to-TV entertainment the way you like it-from the comfort of your couch.
  • BUILT TO KEEP GOING
    K400 is built with the same high quality and reliability standards that have made Logitech the #1 global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. . Up to 18 months of battery life Battery life may vary based on use and computing conditions. eliminates the hassle of frequent battery changes, with a handy on/off switch and power-saving technology that preserve battery life. The spill-resistant Tested under limited conditions (maximum of 60 ml liquid spillage). Do not immerse keyboard in liquid. design and durable keys keep you on-track despite any mishaps
  • QUIET KEYS, LARGE TOUCHPAD
    Comfortable, quiet keys and a large touchpad make navigating entertainment effortless, even setup is a snap thanks to the tiny, plug-and-play USB Unifying receiver
  • WIRELESS AND COMPATIBLE
    Powerful, lag-free wireless gives you up to 10 meters Wireless range may vary based on user, environmental and computing conditions. of freedom with no delays or dropouts. Designed for use with Windows 7, Windows 8, Windows 10 and later, Android 7 or later, and Chrome OS
  • CUSTOMIZABLE
    Use it right out of the box, or customize your controls with Logitech Options software. Preset controls make it easy to adjust volume, make selections, or use your favorite Windows and Android shortcuts
  • DECADES OF DESIGN EXPERTISE
    With more than 22 years experience designing high-quality keyboards, we carefully design, develop, prototype, and study all the essential components of our keyboards, from the core technologies to the comfort and ergonomics of their design. We strive to provide each individual with their ideal typing experience, according to their stature, lifestyle and deskspace
Logitech Wireless Touch Keyboard K400 Plus - keyboard - English
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
English
Hot Keys Function
Multimedia, volume, search, share, devices, settings
Logitech Unifying receiver, on/off power switch, integrated touchpad, low profile keys
35.4 cm x 13.9 cm x 2.35 cm
390 g
Microsoft Certification
Compatible with Windows 7
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Input Device
Wireless
Hot Keys Function
English
Region
United Kingdom
35.4 cm
13.9 cm
2.35 cm
390 g
1 x USB extension cable
Plug and Play
Google Chrome OS, Microsoft Windows 7 / Windows 8, Android 5.0 (Lollipop), Windows 10
AA type
Installed Qty
2
Compatibility: PC
Brand: Logitech
