Logitech Wireless Touch Keyboard K400 Plus
Quicklinx: BP3KWS00 Mfr#: 920-007143
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
£28.53 ex VAT
£34.23 inc VAT
Wireless Touch Keyboard K400 Plus is a full size keyboard layout and touchpad in a compact size. Incurve keys are ideal for touch typists and the soft key stroke makes this a quiet keyboard. The full size touchpad gives you the familiar scroll and navigation gestures. With the left- and right-click buttons below the touchpad and the volume control buttons above, control is at your fingertips. For two-hand control, typically used by those who like to use their thumbs to navigate, a left mouse-click button is located on the upper left side of the keyboard—navigate with your right hand, select with your left.
Logitech Wireless Touch Keyboard K400 Plus - keyboard - English
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
English
Hot Keys Function
Multimedia, volume, search, share, devices, settings
Logitech Unifying receiver, on/off power switch, integrated touchpad, low profile keys
35.4 cm x 13.9 cm x 2.35 cm
390 g
Microsoft Certification
Compatible with Windows 7
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Input Device
Wireless
Hot Keys Function
English
35.4 cm
13.9 cm
2.35 cm
390 g
1 x USB extension cable
Plug and Play
Google Chrome OS, Microsoft Windows 7 / Windows 8, Android 5.0 (Lollipop), Windows 10
AA type
Installed Qty
2
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 0 - 50
