Logitech Wireless Touch Keyboard K400 Plus
Quicklinx: BP3KWS00 Mfr#: 920-007143
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
43 In Stock
£33.19 ex VAT
£39.82 inc VAT
Wireless Touch Keyboard K400 Plus is a full size keyboard layout and touchpad in a compact size. Incurve keys are ideal for touch typists and the soft key stroke makes this a quiet keyboard. The full size touchpad gives you the familiar scroll and navigation gestures. With the left- and right-click buttons below the touchpad and the volume control buttons above, control is at your fingertips. For two-hand control, typically used by those who like to use their thumbs to navigate, a left mouse-click button is located on the upper left side of the keyboard—navigate with your right hand, select with your left.
  • BUILT TO KEEP GOING
    K400 is built with the same high quality and reliability standards that have made Logitech the #1 global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. . Up to 18 months of battery life Battery life may vary based on use and computing conditions. eliminates the hassle of frequent battery changes, with a handy on/off switch and power-saving technology that preserve battery life. The spill-resistant Tested under limited conditions (maximum of 60 ml liquid spillage). Do not immerse keyboard in liquid. design and durable keys keep you on-track despite any mishaps
  • QUIET KEYS, LARGE TOUCHPAD
    Comfortable, quiet keys and a large touchpad make navigating entertainment effortless, even setup is a snap thanks to the tiny, plug-and-play USB Unifying receiver
  • WIRELESS AND COMPATIBLE
    Powerful, lag-free wireless gives you up to 33 ft (10 meters) Wireless range may vary based on user, environmental and computing conditions. of freedom with no delays or dropouts. Designed for use with Windows 7, Windows 8, Windows 10 and later, Android 7 or later, and Chrome OS
  • CUSTOMIZABLE
    Use it right out of the box, or customize your controls with Logitech Options software. Preset controls make it easy to adjust volume, make selections, or use your favorite Windows and Android shortcuts
  • DECADES OF DESIGN EXPERTISE
    With more than 22 years experience designing high-quality keyboards, we carefully design, develop, prototype, and study all the essential components of our keyboards, from the core technologies to the comfort and ergonomics of their design. We strive to provide each individual with their ideal typing experience, according to their stature, lifestyle and deskspace
  • 1
    RECYCLED PLASTICS The plastic parts in K400 PLUS include 60% certified post consumer recycled plastic Excludes plastic in printed wiring assembly (PWA), Touch pad, FFC cable and packaging. - to give a second life to end-of-life plastic from old consumer electronics and help reduce our carbon footprint
  • 2
    CARBON CLARITY We believe everyone should know what they're consuming. The carbon footprint of this product is 4.9 kg CO 2 e. We're working hard to reduce it, and we have offset our residual carbon impact to zero by supporting forestry, renewables and climate-impacted communities
Logitech Wireless Touch Keyboard K400 Plus - keyboard - English Input Device
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
English
Hot Keys Function
Multimedia, volume, search, share, devices, settings
Logitech Unifying receiver, on/off power switch, integrated touchpad, low profile keys
35.4 cm x 13.9 cm x 2.35 cm
390 g
Microsoft Certification
Compatible with Windows 7
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Hot Keys Function
English
Region
United Kingdom
35.4 cm
13.9 cm
2.35 cm
390 g
1 x USB extension cable
Plug and Play
Google Chrome OS, Microsoft Windows 7 / Windows 8, Android 5.0 (Lollipop), Windows 10
AA type
Installed Qty
2
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
