Logitech Wireless Mouse M280 - Blue
Quicklinx: BGWZWS00 Mfr#: 910-004290
Enjoy extra comfort for your right hand through curved grips made of soft rubber. Go longer between battery changes thanks to the energy efficient engineering. Plus, M280 automatically puts itself to sleep when you're not using it.
Get ultra precision and responsiveness with Logitech Advanced Optical Tracking. Plug it once and forget it. Nano receiver gives you a convenient and reliable wireless connectivity.
  • Crafted for your hand
  • 18-month battery life
    Go longer between battery changes thanks to our energy efficient engineering. Plus, M280 automatically puts itself to sleep when you're not using it
  • Smooth and precise tracking
  • Plug-and-forget Nano receiver
Logitech M280 - mouse - 2.4 GHz - blue
Mouse
Wireless - 2.4 GHz
Blue
Orientation
Right-handed
6.79 cm x 10.54 cm x 3.84 cm
91 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Nano wireless receiver, scrolling wheel, auto sleep mode, Logitech Advanced Optical Tracking, battery indicator, on/off power switch
AA type
Apple MacOS X 10.5 or later, Microsoft Windows Vista / 7 / 8, Google Chrome OS, Linux Kernel 2.6 or later
Mouse
Wireless Receiver
Orientation
Right-handed
6.79 cm
10.54 cm
3.84 cm
91 g
Blue
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
1 AA battery
AA type
Run Time (Up To)
18 months
