Enjoy extra comfort for your right hand through curved grips made of soft rubber. Go longer between battery changes thanks to the energy efficient engineering. Plus, M280 automatically puts itself to sleep when you're not using it.
Get ultra precision and responsiveness with Logitech Advanced Optical Tracking. Plug it once and forget it. Nano receiver gives you a convenient and reliable wireless connectivity.
COMFORT MEETS SIMPLICITY
M280 lets you cruise through your busy day with a whole new degree of comfort. The curved and patterned grip naturally fits your hand as you track and scroll with excellent accuracy. The long-lasting battery, broad compatibility, and the strong wireless connection ensure high reliability and ease of use -
ALL-DAY COMFORT
M280 is a result of Logitech's expertise and innovative approach designing comfortable solutions for over 25 years. Its asymmetric shape is meticulously crafted to guide your right hand to a natural position, while the distinctive patterns improves touch feeling. All that allows you to work or study comfortably for hours -
EASY NAVIGATION, PRECISE CONTROL
Track and scroll with excellent accuracy and precision. M280 features a rubber scroll wheel with tactile feel that gives you a controlled line-by-line scrolling experience. Logitech's high precision tracking offers next-level cursor control for great navigation on almost any surface -
PLUG & PLAY SIMPLICITY
Setting up M280 is a snap. It works seamlessly on most OS, including Windows, macOS, and Linux. Start working in seconds by simply plugging the USB receiver into your computer or laptop. The receiver provides a strong, reliable, and flawless wireless connection within up to 10 meters (33 feet) -
QUALITY YOU CAN COUNT ON
M280 is made to be durable and reliable, it works up to 18 months without changing batteries -
BROAD COMPATIBILITY
M280 works seamlessly on most OS, including Windows, macOS, and Linux -
DECADES OF DESIGN EXCELLENCE
We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
- Logitech M280 - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right-handed
- 6.79 cm x 10.54 cm x 3.84 cm
- 91 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, auto sleep mode, Logitech Advanced Optical Tracking
- Battery
- AA type
- OS Required
- Linux Kernel 2.6 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Microsoft Windows Vista / 7 / 8
- Works With Chromebook
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 6.79 cm
- 10.54 cm
- 3.84 cm
- 91 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Included Accessories
- 1 AA battery
- AA type
- Run Time (Up To)
- 18 months
- OS Required
- Limited warranty - 2 years
