Logitech Wireless Mouse M235 - Optical - 2.4 GHz USB wireless receiver - Silver
Wireless Mouse M235
CLEARANCE!
Clearance
Price Drop
Quicklinx: 7HSFWS00 Mfr#: 910-002201
Recommended Use: Mobile, Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Grey
Compatibility: Mac, PC
More than 50 In Stock
£18.03 ex VAT
£21.63 inc VAT
The feel-good, reliable mouse with more precise navigation and soft rubber grips.
From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Logitech® Advanced Optical Tracking
Enjoy precise clicking and pointing--on surfaces other optical mice can't handle--while navigating your favorite websites thanks to Logitech Advanced Optical Tracking.
Logitech Advanced 2.4 GHz wireless connectivity
You get the reliability of a cord with wireless convenience and freedom--fast data transmission and virtually no delays or dropouts.
1-year battery life
You can go for a year without battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises
Plug-and-forget nano-receiver
So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about broken or lost receivers.
Compact comfort
You'll enjoy more comfort and ease thanks to this compact mouse's hand-friendly, contoured design with soft rubber grips and a smooth scroll wheel.
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice--plus a three-year limited hardware warranty.
Perfect for laptops and netbooks
Your mouse works with Windows®, Mac® and Linux®. No matter what type of computer you own today--or buy tomorrow--you can depend on your mouse to work like you expect.
  • Contoured design
    Designed to keep either hand happy. Soft side grips and a comfortable shape-so you'll feel good, even after long hours of use
  • 1-year battery life
    You can go for a year without battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises. 2
  • Logitech reliability
    You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty
  • Logitech Advanced Optical Tracking
    Enjoy precise clicking and pointing-on surfaces other optical mice can't handle-while navigating your favorite websites thanks to Logitech Advanced Optical Tracking
  • Logitech Unifying receiver
    The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard-without the hassle of multiple USB receivers
  • Comfort anywhere
    The compact contoured design with soft rubber grips keeps you comfortable-even when you're on the go
  • Good-bye, tricky touchpad
    You'll enjoy smooth cursor control, precise tracking and easy text selection on the surfaces where you use your computer most
  • Six-in-one power
    The tiny Logitech Unifying receiver connects up to six Unifying-compatible devices with a powerful, reliable wireless connection (up to 25 meters)
  • Year-long battery
    You can go a full year without battery hassles. The On/Off switch helps conserve power, smart sleep mode extends battery life and an indicator light eliminates surprises
Logitech M235 - mouse - 2.4 GHz - grey
Mouse
Wireless - 2.4 GHz
Grey
Orientation
Right-handed
5.5 cm x 9.5 cm x 3.86 cm
84 g
Western Europe
Wireless Receiver
Movement Detection Technology
Optical
Scrolling wheel, rubber side grips, battery indicator, on/off power switch
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Orientation
Right-handed
5.5 cm
9.5 cm
3.86 cm
84 g
Grey
Western Europe
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
1 AA alkaline battery
AA type
Alkaline
Installed Qty
1
Run Time (Up To)
1 year
Shipping Width
12.6 cm
Shipping Depth
18.6 cm
Shipping Height
8.3 cm
Shipping Weight
131 g
Limited warranty - 3 years
Recommended Use: Leisure
Type: Mouse
Colour: Grey
Compatibility: Mac
Compatibility: PC
Brand: Logitech
