Logitech Wireless Mouse M185 - wireless - 2.4 GHz - USB wireless receiver - blue
Quicklinx: 8HBPWS00 Mfr#: 910-002236
Recommended Use: Office, Mobile
Type: Mouse
Wired / Wireless: Wireless
Colour: Blue
Compatibility: PC, Mac
Hurry, only 1 left in stock!
£12.18 ex VAT
£14.61 inc VAT
Logitech Wireless Mouse M815 is a simple, reliable mouse with Plug and Play wireless. You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. You'll enjoy the high quality and reliability. The tiny nano receiver works right away without software and is small enough to leave in your USB port, so you won't lose it. And on top of that, this comfy, contoured mouse treats your hand right.
  • Comfortable Shape, Compact Design
    Stay productive longer with the comfortable, contoured shape that follows the natural curve of your hand. Compact and wireless, the mouse fits easily with your laptop in a bag-so you can take it anywhere you work. M185 is designed to be equally comfortable for both left- and right-handed users
  • Easy Navigation, Precise Control
    M185 provides a controlled line-by-line scrolling experience for easier navigation. No more annoying missed clicks-the optical sensor allows you to track with smooth and accurate cursor control on almost any surface
  • Quality You Can Rely On
    The mouse is built with the same high quality standards that have made Logitech the global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. . Durable and reliable, M185 also works up to 12 months Battery life may vary based on use and computing conditions. without changing batteries thanks to the on/off switch button and auto-sleep power-saving mode
  • PLUG & PLAY SIMPLICITY
    M185 is compatible with Windows , macOS, Chrome OS and Linux and works instantly when you plug the USB receiver into your computer or laptop. The receiver also provides a strong, reliable connection within up to 10 meters. Wireless range may vary based on user, environmental and computing conditions
  • COMPLETE TASKS FASTER
    Get more done by adding M185 to your laptop. According to a recent study, laptop users who chose this mouse over a touchpad were 50% more productive Based on throughput computation in bits/second combining speed and accuracy averaged for all devices participating in the study. Logitech Ergonomic Lab study on 23 participants in (Oct / 2019) with two Logitech standard mice and two standard, embedded trackpads and worked 30% faster Based on bits/second for averaged movement time for all devices participating in the study. Logitech Ergonomic Lab study on 23 participants in (Oct / 2019) with two Logitech standard mice and two standard, embedded trackpads
  • Decades of Design Excellence
    We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
Logitech M185 - mouse - 2.4 GHz - blue
Mouse
Wireless - 2.4 GHz
Blue
Wireless Receiver
Movement Detection Technology
Optical
Nano wireless receiver
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Blue
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
Plug and Play
AA type
Installed Qty
1
Run Time (Up To)
1 year
Limited warranty - 3 years
Recommended Use: Mobile
Type: Mouse
Colour: Blue
Compatibility: PC
Compatibility: Mac
Brand: Logitech
