Logitech Wireless Mouse M175 - Black
Quicklinx: BGXJWS00 Mfr#: 910-002777
Logitech Wireless Mouse M175 is a simple, reliable mouse with Plug-and-Play wireless. You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. The 1-year battery life means fewer hassles, too. You'll enjoy the high quality and reliability that have made Logitech the global leader for mice. The tiny nano receiver works right away without software and is small enough to leave in your USB port so you won't lose it. And on top of that, this comfy, contoured mouse treats your hand right.
Logitech M175 - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
6 cm x 9.9 cm x 3.9 cm
75 g
Western Europe
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Scrolling wheel, on/off power switch, Nano wireless receiver
1 x AA type
Apple MacOS X 10.4 or later, Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
3-year warranty
Mouse
Wireless Receiver
6 cm
9.9 cm
3.9 cm
75 g
Western Europe
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
Plug and Play, RoHS
AA type
Installed Qty
1
Run Time (Up To)
1 year
Limited warranty - 3 years
