Logitech Wireless Mouse M175 is a simple, reliable mouse with Plug-and-Play wireless. You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. The 1-year battery life means fewer hassles, too. You'll enjoy the high quality and reliability that have made Logitech the global leader for mice. The tiny nano receiver works right away without software and is small enough to leave in your USB port so you won't lose it. And on top of that, this comfy, contoured mouse treats your hand right.
- Logitech M175 - mouse - 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- 6 cm x 9.9 cm x 3.9 cm
- 75 g
- Localisation
- Western Europe
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Scrolling wheel, on/off power switch, Nano wireless receiver
- Battery
- 1 x AA type
- OS Required
- Apple MacOS X 10.4 or later, Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
- 3-year warranty
- Mouse
- Wireless Receiver
- 6 cm
- 9.9 cm
- 3.9 cm
- 75 g
- Localisation
- Western Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- 1 x USB - 4 pin USB Type A
- Plug and Play, RoHS
- AA type
- Installed Qty
- 1
- Run Time (Up To)
- 1 year
- OS Required
- Limited warranty - 3 years
