Brand
Logitech Wireless Keyboard K360 2.4GHz UK layout
Quicklinx: 7X93WS00 Mfr#: 920-003082
Recommended Use: Leisure, Mobile
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
£30.91 ex VAT
£37.09 inc VAT
The wireless keyboard that's beautifully convenient and conveniently compact thanks to its space-saving design with familiar layout, long battery life and instant access to the things you do most.
The perfect laptop companion - this compact keyboard lets you type with more comfort while taking up less space. The long battery life is so hassle-free you just might forget it uses batteries at all. You can do more, faster with six hot keys and twelve programmable F-keys for instant access to music, email and more.
  • COMPACT, WIRELESS KEYBOARD
    K360 is ready when you are. This compact wireless keyboard is ideal for narrower built and allows you to perform even in constricted workspaces. Equipped with a number pad and 12 easy access keys, you can be more productive -at home or at work
  • SPACE SAVING LAYOUT
    With a compact design, K360 features all the keys you need, including a number pad and instant access to FN shortcuts-and is 20% smaller than a full-size keyboard. Perfect for tight workspaces, or smaller frames, so you can place your mouse closer for less reaching and better body posture. Plus, it's easy to move anywhere your work takes you
  • COMFORTABLE AND QUIET
    The framed keys give you a comfortable, precise and quiet typing experience, while the tight, modern, glossy design with height-adjustable tilt legs gives your setup just the right amount of edge
  • MAXIMISE PRODUCTIVITY
    Twelve F-keys give you easy access to the functions you need most- open and close windows, applications, emails and more. The six media hot keys let you instantly turn on music, play, pause, skip-so you can stay in the flow
  • BUILT TO KEEP GOING
    With an included 3-year warranty, K360 is built with the same high quality and reliability standards that have made Logitech the #1 global leader for mice and keyboards. Up to 36 months of battery life eliminates the hassle of frequent battery changes, with a handy on/off switch and power-saving technology that preserve battery life
  • PLUG AND PLAY WIRELESS
    Forget about drop-outs and delays thanks to a strong, reliable wireless connection with up to 10 m range. The K360 comes with a Logitech Unifying USB receiver that lets you pair up to six compatible Logitech tools, so you can add your Logitech mouse to that same receiver. Fewer cords, less hassle
Logitech Wireless Keyboard K360 - keyboard - English
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
English
Hot Keys Qty
18
Logitech Unifying receiver
38.1 cm x 15.6 cm x 1.9 cm
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Input Device
Wireless
Hot Keys Qty
18
English
38.1 cm
15.6 cm
1.9 cm
Plug and Play
Microsoft Windows Vista / XP / 7
AA type
Installed Qty
2
Limited warranty - 3 years
Recommended Use: Mobile
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
