Cut loose from your PC with this lightweight, portable headset. The laser-tuned drivers and 10-meter range make it easy to listen and chat whether you're at your desk or on the couch.
WIRELESS AUDIO
Insert the leave-in nano receiver into a USB port and move freely around home or office, up to 33 feet (10 m) away from your computer. Enjoy up to six hours of wireless audio with the rechargeable battery -
RICH STEREO SOUND
Laser-tuned drivers provide enhanced, digital audio for full immersion in music, games and calls -
NOISE CANCELING MIC
Flexible mic can be positioned for better voice capture and background noise reduction. Right-sided boom can be tucked inside the headband and out of the way when you're not using it -
ON-EAR CONTROLS
Power on and off, adjust the volume or mute your calls with simple on-ear controls located on the right ear cup. Store the nano-receiver along bottom of the left ear cup when you're on-the-go -
PADDED COMFORT
Adjustable padded headband with swivel-mounted foam ear cushions are ultra-comfortable even after hours of listening. Headset folds up easily for portability -
USB RECEIVER
Simply insert the nano-receiver into your computer USB port and forget about it- you're ready to talk, listen to music or game. Charge via the included USB cable; even talk while it's charging. Enjoy up to six hours of wireless audio with the rechargeable battery
- Logitech Wireless Headset H600 - headset
- Product Type
- Headset - 2.4 GHz - wireless
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- 2.4 GHz radio frequency
- Radio Frequency Range
- 2.4GHz
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Product Type
- Recommended Use
- Computer
- Max Operating Distance
- 10 m
Audio Output
- On-ear
- Wireless
- Sound Output Mode
- Stereo
Microphone
- Boom
Wireless Link
- 2.4GHz
- Transmission Range
- 10 m
- Connector Type
- USB (4 PIN USB Type A)
- Included Accessories
- Wireless adapter
- Cable Details
- USB charge cable
- Battery
- Headphone battery
- Run Time (Up To)
- 6 hour(s)
- Limited warranty - 2 years
