Wireless Gamepad F710 is a wireless, familiar-feeling gamepad with broad game support and dual vibration feedback lets you feel every hit, crash and explosion in your PC games.
2.4 GHz wireless connection
Cut the cord and enjoy the freedom-gaming without wires. Simply insert the nano-receiver into a USB port for fast, 2.4 GHz data transmission with virtually no delays, dropouts or interference -
Dual vibration feedback motors
Discover a new level of feedback you can feel with every hit, crash and explosion in games that support vibration feedback -
Extensive game support
Play console ports with their native-style controller or adopt a more relaxed position while enjoying PC games. F710 is easy to set up and use with your favorite games thanks to XInput/DirectInput-the two most common input standards -
Steam Big Picture
Pair F710 with Big Picture and navigate Steam, surf the web, play games and more from the comfort of your couch. Bring your entire library of Steam games to the living room, grab your F710, sit back, and enjoy -
Exclusive 4-switch D-pad
Standard D-pads rest on a single pivot point that can result in imprecise control. The D-pad glides over four individual switches for a more responsive, tactile feel -
Familiar console-like layout
Your instincts will guide your actions over the familiar layout and you'll be off and gaming in no time. Crafted for a console-like controlling experience and innovated from traditional design, F710 fits like a glove -
Works with Android TV
Our game controllers work with Sony Android TVs. With the controller switch in XID mode, our console-like layout will give you the edge as you compete. Smooth curves and contoured rubber grips provide long, comfortable play sessions. Standard Android TV controls - provided through the Logitech Logo button on the gamepad together with the Back key on the controller - allow you to navigate your Android TV seamlessly. Learn how to use Logitech gamepad buttons with Android TV -
Easy to set up and use
Change the standard commands or adapt F710 for play with an unsupported title, using Logitech's profiler software. Buttons and controls are programmable and can even mimic keyboard and mouse commands -
Comfortable grip
Enjoy long, comfortable play sessions thanks to smooth curves and contoured rubber grips
- Logitech Wireless Gamepad F710 - gamepad - wireless - 2.4 GHz
- Product Type
- Gamepad
- Connectivity Technology
- Wireless - 2.4 GHz
- Buttons Qty
- 10
- Controls
- Dual analogue sticks, Back button, Start button, Home button, 2 analogue triggers, 8-way D-pad
- Vibration-feedback, force feedback, rubber side grips, fully programmable buttons, sports mode, vibration on/off button
- Designed For
- PC
- Product Type
- Gamepad
- Buttons Qty
- 10
- Controls
- Interface
- USB
- OS Required
- Microsoft Windows Vista / XP / 7
- Required Battery
- AA type
- Included Accessories
- Receiver adapter, USB extension cable, 2 batteries
- Software Included
- Drivers & Utilities
- Designed For
- PC
