Logitech Wireless Desktop MK710 - keyboard and mouse set
Quicklinx: 735WWS00 Mfr#: 920-002429
Comfort and productivity go hand-in-hand thanks to concave keys, a cushioned palm rest and a hyper-fast scrolling mouse.
Three-year battery life
The batteries in both the keyboard and mouse last up to three full years, so you can forget the hassle, expense and waste of frequent battery changes
Logitech® Incurve keys™
Concave keys with softly-rounded edges position your fingers properly and invite your fingertips to glide from key to key--keeping you comfortable for hours
Low profile, longer key travel
Not easily found on many low-profile and laptop keyboards, longer key travel improves comfort and your overall typing experience
Cushioned palm rest
Your hands can relax--the cushioned palm rest feels so much better than hard plastic.
Sculpted mouse
It positions your hand and fingers comfortably and naturally
Hyper-fast scrolling
You'll fly through long documents and Web pages with just a flick of the nearly frictionless scroll wheel
LCD dashboard
It gives you at-a-glance icon status of your battery, Caps Lock, Scroll Lock and Num Lock, so you won't skip a beat while typing
Logitech® Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add another compatible wireless mouse or keyboard--without the hassle of multiple USB receivers
Logitech® Advanced 2.4 GHz wireless connectivity
You can confidently work and play where you please. Encrypted, secure cordless technology ensures you a reliable connection with virtually no lags or dropouts
  • COMFORT MEETS PERFORMANCE
    Because comfort and performance shouldn't be mutually exclusive. Meet the mouse and keyboard combo that combines the best of both worlds. A full-size keyboard is fully loaded with a LCD display, number pad, and palm rest, so you can work at peak efficiency and comfort. The contoured mouse is sculpted for the shape of your right hand, and features programmable buttons, hyper-fast scrolling, and precision tracking that works on most surfaces
  • TYPE AT MAX COMFORT
    The full-sized keyboard features a numpad for better efficiency, and a cushioned palm rest for maximum comfort. Concave keys position your fingers properly, while softly rounded edges invite your fingertips to glide quietly from key to key, hour after hour
  • FULL-SIZED COMFORTABLE MOUSE
    The included full-size mouse is built for the long haul thanks to its sculpted shape, right-handed design, and rubber side-grips for added comfort. The shape follows the natural curve of your hand, so you can stay productive longer-whether you're in the office or at home
  • HYPER-FAST SCROLLING
    The mouse features precision tracking for accurate cursor control on most surfaces. Plus, the dual-mode scrolling lets you switch between speed and precision, so you can fly through long documents or go line-by-line, at the touch of a button. Use Logitech Options to boost your productivity by customizing the extra thumb buttons and tilt wheel
  • LCD DASHBOARD
    An LCD dashboard of the keyboard gives you at-a-glance icon status of your battery, Caps Lock, Scroll Lock and Num Lock, so you won't skip a beat while typing
  • UNIFYING WIRELESS BY LOGITECH
    Work wirelessly from up to 10 meters away with a strong, reliable 2.4 GHz USB receiver connection for virtually no delays or dropouts. Logitech Unifying technology lets you pair as many as six compatible peripherals to a single tiny Unifying receiver
  • EXTRA LONG BATTERY LIFE
    This combo is built with the same high quality standards that have made Logitech the global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only . Durable and reliable, this combo is designed with ultra efficient battery consumption so that you can work up to three yearsKeyboard and mouse battery life may vary based on user and computing conditionswith the included batteries . The keyboard is ready to withstand on-the-job use and mishaps thanks to the spill-resistant design. Tested under limited conditions (Maximum of 60 ml liquid spillage). do not immerse the keyboard in liquid
Logitech Wireless Desktop MK710 - keyboard and mouse set - UK Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
Palm rest
Pointing Device
Mouse
Microsoft Certification
Compatible with Windows 7
5-year warranty
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 46.03 cm x 24.23 cm x 3.1 cm / 860 g , Mouse: 7.1 cm x 10.9 cm x 4.2 cm / 88 g
Wireless
Region
United Kingdom
Palm rest
Pointing Device
Mouse
Included Software
Drivers & Utilities
Microsoft Windows Vista / XP / 7
AA type
Installed Qty
4
Alkaline
Limited warranty - 5 years
