Logitech Wireless Combo MK330 - Keyboard and mouse set
Quicklinx: 8KK6WS00 Mfr#: 920-003986
More than 50 In Stock
£28.58 ex VAT
£34.29 inc VAT
The combo that puts entertainment and portability at your fingertips--thanks to 11 hot keys and a go-anywhere mouse.
Multimedia hot keys
Skip a song. Pause a video. Turn up the volume. You get 11 multimedia hot keys for instant access to play, pause, previous, next, volume and mute.
Sleek, comfortable design
The keyboard's sleek design and low-profile, whisper-quiet keys make for a more comfortable typing experience than laptop and netbook keyboards.
Portable wireless mouse
You can take the sleek mouse anywhere you take your computer. Plus, the included storage compartment makes it easy to store the nano-receiver.
Extended battery life
A 24-month keyboard and 12-month mouse battery life mean you can go for months without the hassle of changing batteries.
Advanced 2.4 GHz wireless
So you can work or play in more places--like your comfy couch--the long-range wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10 meters
Plug-and-play simplicity
Setup couldn't be easier--you simply plug the wireless receiver into a USB port on your computer and you'll be exploring MSN, shopping online and searching Google right away without software.
12 programmable F-keys
You're in charge with programmable F-keys that you can easily customize to open your favorite applications, folders or web pages.
*Logitech Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse, keyboard or number pad--without the hassle of multiple USB receivers
  • Sleek design
    The full-size keyboard's low-profile, whisper-quiet keys make typing efficient and comfortable. The mouse's gentle curve makes it comfortable for all-day use
  • Plug-and-play simplicity
    Setup couldn't be easier, so you can get right to business
  • Extended battery life
    Up to 2 years for the keyboard and 1 year for the mouse to minimize recharging hassle
  • Eleven multimedia hot keys; 4 programmable F-keys
    Enables instant access to multimedia options, the Internet, e-mail, play/pause, volume and more for meetings and conferences; allows you to re-program the F-keys to open your favorite applications, folders or webpages
Logitech Wireless Combo MK330 - keyboard and mouse set - UK - black Input Device
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
Hot Keys Qty
17
Hot Keys Function
Sleep, application switching, My Computer, e-mail, volume, search, mute, Show Desktop, lock computer, play/pause, previous track, next track, media player
Pointing Device
Mouse - optical
Buttons Qty
3
On/off power switch, 1000 dpi resolution
3-year warranty
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 42.5 cm x 18 cm x 2.2 cm / 570 g , Mouse: 5.9 cm x 10 cm x 3.75 cm / 76 g
Wireless
Keyboard Name
Logitech Wireless Keyboard K330
Hot Keys Qty
17
Hot Keys Function
Pointing Device
Mouse
Pointing Device Name
Logitech Wireless Mouse M215
Buttons Qty
3
Movement Detection Technology
Optical
Pointing Device Features
USB extender
Plug and Play
Microsoft Windows Vista / XP / 7
AA / AAA
Installed Qty
3
Required Qty
3
Alkaline
Limited warranty - 3 years
