FAVOURITE WIRELESS COMBO
MK270 Wireless Combo brings together the convenience and comfort of a full-sized keyboard with a sculpted, compact mouse. With media keys, a number pad and precise cursor control to make your work a whole lot smoother. Plus, the lag-free wireless makes setup easy and saves space on your desk. No wonder this is the world best selling combo! -
FULL-SIZE KEYBOARD
Comfortable, full-sized, and efficient. Complete with easy access to media controls, this keyboard lets you get more done in less time with eight media controls that let you instantly access to music, media, volume, and more -
COMFORTABLE COMPACT MOUSE
Stay productive longer with the comfortable, contoured shape that follows the natural curve of your hand. This compact and wireless mouse is designed to be equally comfortable for both left- and right-handed users. Plus, it´s smooth cursor control allows you easy navigation on most surfaces -
SIMPLY WIRELESS
Forget about drop-outs and lag thanks to a strong, reliable 2.4 GHz wireless connection with a 10 m range. Free up your desk with a USB receiver-so tiny, it can stay in your computer. Wireless range may vary due to environmental and computing conditions -
RELIABLE AND DURABLE
Enjoy the familiar typing of MK270, the world's best-selling combo, built with the same high quality and reliability standards that have made Logitech the global leader for mice and keyboards. Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only -
BUILT TO KEEP GOING
The keyboard comes with a spill-resistant design, durable keys, and sturdy tilt legs with adjustable height. A 36-month keyboard and 12-month mouse battery life-along with on/off switches-means you can go for months without the hassle of changing batteries. Tested under limited conditions (Maximum of 60 ml liquid spillage). do not immerse the keyboard in liquid. Keyboard and mouse battery life may vary based on user and computing conditions
- Logitech MK270 Wireless Combo - keyboard and mouse set - Spanish Input Device
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- Spanish
- Hot Keys Qty
- 8
- Hot Keys Function
- Internet browsing, calculator, e-mail, volume, mute, play/pause
- On/off power switch
- Pointing Device
- Mouse - optical
- Buttons Qty
- 3
- Scrolling wheel, wireless, on/off power switch, 1000 dpi resolution
- 3-year warranty
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 44.1 cm x 14.9 cm x 1.8 cm / 481 g , Mouse: 6 cm x 9.9 cm x 3.9 cm / 50 g , Wireless receiver: 1.4 cm x 1.9 cm x 0.6 cm / 2 g
- Wireless
- Keyboard Name
- Logitech Wireless Keyboard K270
- Hot Keys Qty
- 8
- Hot Keys Function
- Spanish
Pointing Device
- Mouse
- Pointing Device Name
- Logitech Wireless Mouse M185
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Pointing Device Features
- Included Accessories
- USB extender
- Plug and Play
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- AA / AAA
- Installed Qty
- 3
- Required Qty
- 3
- Technology
- Alkaline
- Limited warranty - 3 years
