Logitech Wireless Combo MK270 - Keyboard and mouse set - 2.4  - French Layout
Quicklinx: BMR2WS00 Mfr#: 920-004510
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
24 In Stock
£26.60 ex VAT
£31.92 inc VAT
Work or play in more places. The wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10-meters range.
Take the mouse with you. This comfortable mouse fits easily into computer bags and pocket to travel with your computer.
A 24-month keyboard and 12-month mouse battery life - plus on/off switches - means you can go for months without the hassle of changing batteries.
Instant access to media controls - movies, music, Internet, e-mail, play/pause, volume and more - are one touch away.
The full-size keyboard with number pad, directional keys, and nine F-keys is comfortable, convenient and built to last.
  • Advanced 2.4 GHz wireless
    Work or play in more places. The wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10-meters range. 1
  • Compact mouse
  • Extended battery life
    A 36-month keyboard and 12-month mouse battery life-plus on/off switches-means you can go for months without the hassle of changing batteries
  • Eight shortcut keys
    Instant access to media controls-movies, music, Internet, e-mail, play/pause, volume and more-are one touch away
  • Full-size keyboard
  • Long-range wireless
    Fast, reliable connection up to 10-meters with virtually no delays or dropouts thanks to Logitech Advanced 2.4 wireless technology
  • On-the-go mouse
    Take this compact mouse anywhere your computer goes
  • Long battery life
    Go for months without changing batteries. On/Off switches help conserve battery use
Logitech MK270 Wireless Combo - keyboard and mouse set - French Input Device
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
French
Hot Keys Qty
8
Hot Keys Function
Internet browsing, calculator, e-mail, volume, mute, play/pause
On/off power switch
Pointing Device
Mouse - optical
Buttons Qty
3
Scrolling wheel, wireless, on/off power switch, 1000 dpi resolution
3-year warranty
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 44.1 cm x 14.9 cm x 1.8 cm / 481 g , Mouse: 6 cm x 9.9 cm x 3.9 cm / 50 g , Wireless receiver: 1.4 cm x 1.9 cm x 0.6 cm / 2 g
Wireless
Keyboard Name
Logitech Wireless Keyboard K270
Hot Keys Qty
8
Hot Keys Function
French
On/off power switch
Pointing Device
Mouse
Pointing Device Name
Logitech Wireless Mouse M185
Buttons Qty
3
Movement Detection Technology
Optical
Pointing Device Features
USB extender
Plug and Play
Included Software
Drivers & Utilities
Microsoft Windows Vista / XP / 7 / 8
AA / AAA
Installed Qty
3
Required Qty
3
Alkaline
Limited warranty - 3 years
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
