Logitech Wireless Combo MK270 - Keyboard and mouse set - 2.4  - French Layout
Quicklinx: BMR2WS00 Mfr#: 920-004510
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
£25.96 ex VAT
£31.15 inc VAT
Work or play in more places. The wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10-meters range.
Take the mouse with you. This comfortable mouse fits easily into computer bags and pocket to travel with your computer.
A 24-month keyboard and 12-month mouse battery life - plus on/off switches - means you can go for months without the hassle of changing batteries.
Instant access to media controls - movies, music, Internet, e-mail, play/pause, volume and more - are one touch away.
The full-size keyboard with number pad, directional keys, and nine F-keys is comfortable, convenient and built to last.
  • FAVOURITE WIRELESS COMBO
    MK270 Wireless Combo brings together the convenience and comfort of a full-sized keyboard with a sculpted, compact mouse. With media keys, a number pad and precise cursor control to make your work a whole lot smoother. Plus, the lag-free wireless makes setup easy and saves space on your desk. No wonder this is the world best selling combo!
  • FULL-SIZE KEYBOARD
    Comfortable, full-sized, and efficient. Complete with easy access to media controls, this keyboard lets you get more done in less time with eight media controls that let you instantly access to music, media, volume, and more
  • COMFORTABLE COMPACT MOUSE
    Stay productive longer with the comfortable, contoured shape that follows the natural curve of your hand. This compact and wireless mouse is designed to be equally comfortable for both left- and right-handed users. Plus, it´s smooth cursor control allows you easy navigation on most surfaces
  • SIMPLY WIRELESS
    Forget about drop-outs and lag thanks to a strong, reliable 2.4 GHz wireless connection with a 10 m range. Free up your desk with a USB receiver-so tiny, it can stay in your computer. Wireless range may vary due to environmental and computing conditions
  • RELIABLE AND DURABLE
    Enjoy the familiar typing of MK270, the world's best-selling combo, built with the same high quality and reliability standards that have made Logitech the global leader for mice and keyboards. Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only
  • BUILT TO KEEP GOING
    The keyboard comes with a spill-resistant design, durable keys, and sturdy tilt legs with adjustable height. A 36-month keyboard and 12-month mouse battery life-along with on/off switches-means you can go for months without the hassle of changing batteries. Tested under limited conditions (Maximum of 60 ml liquid spillage). do not immerse the keyboard in liquid. Keyboard and mouse battery life may vary based on user and computing conditions
Logitech MK270 Wireless Combo - keyboard and mouse set - French Input Device
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
French
Hot Keys Qty
8
Hot Keys Function
Internet browsing, calculator, e-mail, volume, mute, play/pause
On/off power switch
Pointing Device
Mouse - optical
Buttons Qty
3
Scrolling wheel, wireless, on/off power switch, 1000 dpi resolution
3-year warranty
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 44.1 cm x 14.9 cm x 1.8 cm / 481 g , Mouse: 6 cm x 9.9 cm x 3.9 cm / 50 g , Wireless receiver: 1.4 cm x 1.9 cm x 0.6 cm / 2 g
Wireless
Keyboard Name
Logitech Wireless Keyboard K270
Hot Keys Qty
8
Hot Keys Function
French
On/off power switch
Pointing Device
Mouse
Pointing Device Name
Logitech Wireless Mouse M185
Buttons Qty
3
Movement Detection Technology
Optical
Pointing Device Features
USB extender
Plug and Play
Included Software
Drivers & Utilities
Microsoft Windows Vista / XP / 7 / 8
AA / AAA
Installed Qty
3
Required Qty
3
Alkaline
Limited warranty - 3 years
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
