Logitech Wireless All in One Keyboard TK820 UK Layout
Quicklinx: 8YTCWS00 Mfr#: 920-005136
Everything you need to control and navigate your computer is integrated in one device. The keyboard has a built in touchpad so you can type, touch and swipe in one.
The touch area is larger than a laptop touchpad so you have more room to point, zoom and swipe. The wireless, ultra-slim design keeps your desk cable- and clutter-free. The integrated touchpad also means you won't need a separate mouse.
  • Keyboard with built-in touch pad
    Type and swipe in one. Start typing on the keyboard and then switch to pointing, zooming and swiping on the touchpad. The keyboard and touchpad are seamlessly integrated, so switching between them is smooth and effortless. Even the angle of the all-in-one keyboard is designed to make typing and swiping better together.
  • Large touch area with integrated click
    The large touchpad gives your fingers plenty of room to perform multi-touch gestures like pinch, zoom or swipe. It also allows you to control your cursor more precisely. There are no external buttons. Instead, the entire touchpad surface is a button. To left click, tap or click in the middle of the touchpad. To right click, tap or click in the lower-right corner of the touchpad.
  • Wireless, space-saving design
    The all-in-one keyboard has an ultra-slim design that takes up less space on your desk. It connects wirelessly to your computer, so you don't have to worry about cables getting in the way. The integrated touchpad allows you to navigate the cursor, click and gesture, so you won't need an external mouse.
  • Unifying receiver with advanced 2.4 GHz wireless
    Type with the keyboard in front of your computer or even on your lap. A tiny unifying receiver wirelessly connects the keyboard to your computer - just plug it in and start typing and swiping. The connection is robust and reliable, so you can place the keyboard in the most convenient position for you, and still enjoy fast data transmission with virtually no delays or dropouts.
  • PerfectStroke key system
    Logitech PerfectStroke key system distributes typing pressure evenly across the key surfaces. Every keystroke feels smooth and whisper-quiet - even if you strike the edge of a key.
  • Incurve keys
    Logitech Incurve keys match the natural profile of your fingertips. Each concave key surface has softly rounded edges to help your fingers glide across the keyboard. Typing feels fluid and comfortable, hour after hour.
Logitech Wireless All-in-One TK820 - keyboard - UK
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
PerfectStroke, Logitech Incurve keys, Logitech Unifying receiver, spill-resistant, integrated touchpad, up to 4-finger gesture support
40.95 cm x 14.53 cm x 2.17 cm
783 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Input Device
Wireless
40.95 cm
14.53 cm
2.17 cm
783 g
Microsoft Windows 7, Windows 8
AA type
Installed Qty
2
Limited warranty - 3 years
