Position Rally Bar and Rally Bar Mini below the display for natural eye contact. Mounting directly to the wall saves space and lends a finished appearance to any room.
See Eye-to-Eye
Position Rally Bar and Rally Bar Mini below the display for natural eye contact. Mounting directly to the wall saves space and lends a finished appearance to any room -
The Right Angle
In rooms where above-display mounting makes sense, the 10° tilt down adapter delivers a room-wide view with the right angle for video meetings -
Perfectly Parallel
Engineered for perfectionists. The built-in angle adjustment lets you precisely align the level of your video bar with the display -
Thoughtful Cable Management
The Wall Mount works with your video bar's built-in cable retention cover, so cables can run up, down, or both and stay securely connected -
VESA Compatible, Cart-Friendly
With industry-standard VESA mounting pattern (200 x 50mm), Wall Mount is equally at home on mobile carts for ultimate versatility
 - Logitech Wall Mount For Video Bars - camera mount
- Product Type
 - Camera mount
- Placing / Mounting
 - Cart mountable, wall mountable
- Package Content
 - Screws, tilt down adapter
 - 23.6 cm x 8.4 cm x 10 cm
- Designed For
 - Rally Bar; Room Solution Large
- Product Type
 - Camera mount
- Package Content
 - 23.6 cm
 - 8.4 cm
 - 10 cm
 - VESA 200 x 50 mm
- Designed For
 - Logitech Rally Bar , Logitech Room Solution Large
