Logitech Wall Mount For Rally Bar
Quicklinx: GDWBWS00 Mfr#: 952-000044
34 In Stock
£69.41 ex VAT
£83.29 inc VAT
Position Rally Bar and Rally Bar Mini below the display for natural eye contact. Mounting directly to the wall saves space and lends a finished appearance to any room.
  • See Eye-to-Eye
  • The Right Angle
    In rooms where above-display mounting makes sense, the 10° tilt down adapter delivers a room-wide view with the right angle for video meetings
  • Perfectly Parallel
    Engineered for perfectionists. The built-in angle adjustment lets you precisely align the level of your video bar with the display
  • Thoughtful Cable Management
    The Wall Mount works with your video bar's built-in cable retention cover, so cables can run up, down, or both and stay securely connected
  • VESA Compatible, Cart-Friendly
    With industry-standard VESA mounting pattern (200 x 50mm), Wall Mount is equally at home on mobile carts for ultimate versatility
Logitech Wall Mount For Video Bars - camera mount
Camera mount
Placing / Mounting
Cart mountable, wall mountable
Package Content
Screws, tilt down adapter
23.6 cm x 8.4 cm x 10 cm
Rally Bar; Room Solution Large
Camera mount
Placing / Mounting
Package Content
23.6 cm
8.4 cm
10 cm
VESA 200 x 50 mm
Logitech Rally Bar , Logitech Room Solution Large
Brand: Logitech
