It is a high-quality, high-performance headset that brings your PC calls and music to life. Enjoy volume and bass level control, as well as the ability to instantly mute the mic - all at your fingertips and the soft leatherette padded headband and earcups allow you to talk or listen in comfort, for hours on end.
Soft leatherette padding is easy on your ears - especially when you're listening to music or chatting for hours. Worried about the fit? Don't be. The padding on the headband ensures a fit that molds comfortably to the contours of your head.
HIGH-DEFINITION SOUND QUALITY
Laser-tuned drivers and built-in equalizer provide rich, digital audio for full immersion in music, games and calls. This plug-and-play headset can be used with any PC or Mac computer without the need to install software -
NOISE CANCELING MIC
Minimizes unwanted background noise for clear conversations. Right-sided mic can be conveniently positioned for better voice capture. Discreet boom can be tucked inside the headband and out of the way when you're not using it -
ON-EAR CONTROLS
Adjust the volume or mute your calls with simple on-ear controls located on the right ear cup. Confirm mute status with an easy-to-see light indicator on the headset cord -
PADDED COMFORT
Ultra-comfortable, adjustable design. Soft, padded leatherette headband and ear cups feel good even after hours of listening -
USB CONNECTION
USB provides easy plug-and-play operation. Simply plug the USB connector into your computer and instantly enjoy conversations, movies, or music in rich stereo sound
- Logitech USB Headset H540 - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Volume
- 2-year warranty
- Product Type
- Headset - wired
- Recommended Use
- Computer
Headphones
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
Microphone
- Boom
- Mono
- Sensitivity
- -40 dBV/Pascal
- 100 - 10000 Hz
Remote Control
- Controls
- Volume
- Connector Type
- USB (4 PIN USB Type A)
- Cables Included
- USB cable - 1.8 m
- Limited warranty - 2 years
